Vanilla Overdive & Pepper Shredder ... Erfahrungen
  • 102 Antworten
  • 61484 Aufrufe
Offline hogo-pogo
  • Newbie
  • 4
Re: Vanilla Overdive & Pepper Shredder ... Erfahrungen
« Antwort #75 am: 14.03.2008 16:30 »
Hello,
I have to turn to a German forum because I can't find anything on Vanilla Overdrive & Pepper Shredder at the international one.  I can see  plenty of info in a Haebbe58's post,  only can't understand  anything.
So, could someone (especially the abovementioned builder)  summarise one's experience with these projects?
1)How 12 au7 12 volts plates  operation  compares in overall tone, saturation, dynamics, etc  to  a full-blown 12ax7 at +/- 200 v ?
2) How does it sound with /without a tube amp/PA; any mp3's  DI/miked?
3)Anyone have a layout diagram?
4)whatever.
 Thank you.
  • 12.985
« Antwort #77 am: 15.03.2008 00:40 »
Well, it is hard to comare it that way ! First of all the preamp is designed for low voltage 12 V / 12,6 V and you can not run a 12AX7 with 12 V - OK, you can but it sounds terrible - so the next "best" tube for such an application is the 12U7 or 12AU7. Bothe types are much better suited for this purpose. Second: normaly you can get the same amount of overdrive with a 12AU7 that you get with a 12AX7. OK, this is not 100% correct but just to give a idea.
I do not think it is a good idea to compare it the way. There are a lot of 200V / 12AX7 driven tube amps available which do sound bad but there are also a lot of 20 V / 12AX7 driven preamps on the market which do sound great. So what ?
The question is: what do you want and what do you expect ? The Vanilla is an Overdrive pedal which can also be used as a booster and for me it sounds OK. Of course it should be possible to optimize some things an make the sound somehow "better" (whatever this means) but than the pedal might also loos its simplicity.
All Low-Voltage projects are full working pres but there is still a lot of room left for the customer to bring in other ideas etc which is - due to the low voltage - very interessting for beginners or people who are not that common with high voltage but how want to get in touch with tubes and tube-amps.
This will not work directly. The pedal does not have any frequency correction and you will need a amp/cab simulator. Have you ever played your electrical guitar thru your Stereo ? Than you know what I am talking about  :guitar:
Regards, Dirk
Offline hisseme
  • 17
« Antwort #78 am: 9.07.2008 20:29 »
Hey Folks,
der Vanilla war auch mein erstes Projekt, das kam dann in ein Riffelblechgehäuse und läuft auch super! Ich nutze Röhren vom Typ Tesla ECC 802 S, das sind ECC82 Röhren mit verlängerter Lebensdauer und diese sind auch besonders Rauscharm. Ich habe es auch mit normalen ECC82 von Tesla probiert, sowie mit ECC82 von RFT und ECC82 Made in China...ich muss sagen, es gibt keinen bluesigeren Klang als mit den verbauten zwei Röhren. Ich "befeure" damit meinen Laney LV120H im Cleankanal, damit krieg ich den Sound a la White Stripes ziemlich gut hin, wenn ich dann die Zerre des Amps noch mit anmache, wirds ne Kante härter. Auf eine Tone Regelung hab ich verzichtet, denn dafür hat man ja genug Möglichkeiten über Klampfe und Amp. Wenn ich die Höhen der Gitarre voll reindrehe und Lautstärke voll aufreiße, kommt ein sehr höhenreicher, schriller Ton raus, der dann schon wieder an "Born to be wild" erinnert. Alles in allem ein kleines krasses Kästchen, das doch obwohl es so simpel ist ziemlich viele Möglichkeiten bietet. Befreundete Gitarristen lachen sich immer erstmal schlapp wenn sie den kleinen Kasten mit den 2 Röhren oben drauf sehn, aber der Klang bringt dann viele dazu zu sagen "Ich will auch so eins"
Ist schon krass!
  • 12.985
« Antwort #79 am: 10.07.2008 13:02 »
50 % des Sounds entstehen sowieso im Kopf oder kennst Du jemand der einen Mesa Amp hat und sagt, dass sein Amp nicht gut klingen würde  O0 oder wie man bei uns so sagt: "was der Bauer nicht kennt, frisst er nicht"...
« Antwort #80 am: 10.07.2008 13:10 »
Da ist was dran!
Hab ich selbst bei meinen selbstgebauten Amps festgestellt ... Sobald die in ein vernünftiges Gehäuse (natürlich von TubeTown) eingebaut wurden, klangen sie nochmal besser!
Das Auge isst (oder hört) mit!
:guitar:
Offline loco
  • 1.770
« Antwort #81 am: 10.07.2008 13:14 »
@Dirk -------bedenklich wird es ,sobald es anfängt im Kopf nachzuhallen.  :bier:
« Letzte Änderung: 10.07.2008 13:16 von loco »
  • 12.985
« Antwort #82 am: 10.07.2008 14:11 »
auwei, das ist hart...
Offline Squier51
  • Starter
  • 8
« Antwort #83 am: 12.08.2008 12:29 »
ganz theoretisch wäre es doch möglich den Vanilla Overdrive oder den Pepper Shredder mit ECC802 Röhren zu bestücken, oder???
Falls das geht, wie würde sich das auf den Klang auswirken???
Mfg,
  • 12.985
« Antwort #84 am: 12.08.2008 13:24 »
sollte gehen, aber wie sich das klanglich auswirkt müsste ich auch erst selbst ausprobieren....
Offline Squier51
  • Starter
  • 8
« Antwort #85 am: 12.08.2008 13:52 »
Cool!!! 8)
Würde mich auf alle Fälle brennend interessieren wie das klingt!
Habe eben traurigerweise gelesen das der Pepper Shredder nur schwer am GA-5 zu beherrschen wäre, das war leider genau das was ich eigentlich geplant hatte!  :( Schade!
MFG,
Offline Schäl Sick Blues
  • 25
« Antwort #86 am: 12.08.2008 16:43 »
Das ist zu erwarten und hierfür sind die Teile auch nicht gedacht. Das dürfte bei anderen Amps dieser Art auch nicht viel besser sein.
Hallo Dirk und alle anderen der Röhrengemeinde.
Bin noch ganz neu hier im Forum, sonst leider schon allerhand gelaufen, meine Vorstellung ist bei den Einsteigern zulesen.
Meine Frage: Wenn ich Dirk richtig verstanden habe dann heisst das, der Vanilla geht nicht vor einem VOX AD50VT (Modelingamp mit mini Röhrenendstufe)?
Bluesige Grüsse  :guitar:
vun der Schäl Sick
Wenn du mal den Blues hast, dann lass es raus, spiel ihn
  • 12.985
« Antwort #87 am: 12.08.2008 20:18 »
Weiss ich nicht, habe ich noch nicht ausprobiert bzw. gehen tut der auf alle Fälle nur ob die Klangergebnisse OK sind weiss ich nicht. Es stellt sich ferner die Frage ob das überhaupt sinn macht, denn die DSPs in dem Teil dürften den Sound eigentlich wieder komplett glatt bügeln und ob die eingebaute 12AX7 eine grosse Funkion hat... grosse Zweifel - aber es sieht gut aus und hört sich in der Werbung auch besser an  :devil:
Offline bluesfreak
  • 2.679
« Antwort #88 am: 13.08.2008 09:49 »
MOin,
die ECC83 treibt die (Transistor)Endstufe im Vox, färbt also schon deutlich den Klang. Allerdings nicht mir Vorstufenverzerrung (das macht der DSP bei entsprechender Einstellung) sondern es wird sozuagen Endstufenzerre erzeugt die aus der Röhre kommt und nicht aus der Transistorendstufe...
Allerdings schleß ich mich Deiner Meinung an, ein Vanilla vor so nem amp kann grauslich klingen...
just my 2c
Stefan  8)
  • 12.985
« Antwort #89 am: 13.08.2008 13:31 »
hast Du ggf. einen Schaltplan von dem Teil zur Hand ?
