Neueste Beiträge
#81
Tech-Talk Amps / Antw:TT 18 watt - problems
Letzter Beitrag von Helmholtz - Nov 03, 2026, 10:56
Can you measure the 230V mains voltage between the black and blue primary wires?
#82
Letzter Beitrag von TimA070 - Nov 03, 2026, 10:02
No, I never did connect two wires of the same winding together. Only the brown-grey connection that asks for it to put in series on the primary side, see included photos earlier in the thread. The orange and white wire I cut-off, and put heatshrink on, individually isolated of course.
#83
Letzter Beitrag von Helmholtz - Nov 03, 2026, 09:56
Zitat von: TimA070 am Nov 03, 2026, 09:45Okay, when I took measures between the ends of the windings, I measured like 4 mV AC at both the Pink-Grey connection, as well as the Brown-Brown connection. Which is also strange.
Not sure, what you did.
But must never directly connect two wires of the same winding, because that will cause a short.
#84
Letzter Beitrag von TimA070 - Nov 03, 2026, 09:45
I put a new fuse in before I started measuring tonight. Checked it for continuity as well, the 'old' fuse also checked out for continuity. The schematic asks for a 2 A and 500mA fuse, the TT kit came with two packages of each some 500mA and 2A fuses. However, there's only one fuse-terminal. Took the tubes out as well.
I turned the amp on for just a brief moment for a measurement at each of the points at a time, and to reduce chance of shocking myself accidently. But I'll leave the amp off for now and proceed with the method suggested. I did double, or even triple check the path of grey wires before I soldered them, cause it was a puzzle for sure... But with deducing I was quite confident I made right connections, grrrr...  :-\
Still, the pilot light not turning on is a weird thing indeed... It beeps for continuity when I measure at the two terminals.
#85
Letzter Beitrag von Helmholtz - Nov 03, 2026, 09:10
Zitat von: TimA070 am Nov 03, 2026, 08:12- Between Pink and Grey: 0.3 ohm, at both wires (seperately) I measured 3,9 VAC.
Not sure what you mean with "separately".
Winding voltage is always measured between the ends of the winding (just like resistance) and not ground.
#86
Letzter Beitrag von Showitevent - Nov 03, 2026, 08:53
I have a feeling that the primary side isnt wired correctly.
If the pilot light still doesnt come on, even though its connected before the transformer, the fuse in the AC inlet might be blown.
But STOP!
The 3.9V AC you are measuring on the secondary side could be due to capacitive coupling from somewhere or, in the worst case, there could be a direct connection to the mains.
As Bluesfreak already pointed out: Gray/Pink. I hope you havent mixed up the two gray wires.
"Between Pink and Grey: 0.3 ohm" might indicate that these are correct. But read carefully:
If you measure these wires with the Tube in Place, then you might have read the resistance of the Tube Filament, not the Secondary of the transformer.
However, this still doesnt explain why the pilot light isnt coming on.
Once again, my strong recommendation: DO NOT PLUG IN THE AMPLIFIER until these issues have been identified and resolved.
- Check with an Ohm Meter GREY to WHITE on the Primary.
  These should give you a low reading. Then you know that you have the right grey on the primary side.
- Check GREY to PURPLE on the secondary with the Tube unplugged.
  A low reading indicates that these belong together
- Make sure you dont have any low reading between any of the secondary wires to any of the primary wires
- Check the Mains inlet fuse. It is located in the IEC Terminal.
According to the Docs you posted, there is a third grey wire which belongs to the centertap of the high voltage.
Cheers,
Geronimo
#87
Letzter Beitrag von TimA070 - Nov 03, 2026, 08:12
Why are there so many gray wires?!?! Hahaha...
So I just had time to do some measurements (DC resistance and some VAC) and here are my findings:
- Between Blue and Black: 18 ohm.
- Between Brown and Brown: 1.1 ohm. But at both wires seperately I still measure like 4 mV AC (?!!).
- Between Purple and Purple: 222 ohm and 300 mV AC (?!!).
#88
Tech-Talk Amps / Aufbau Kasha Rockmod II Preamp
Letzter Beitrag von sechssaitenmann - Nov 03, 2026, 07:17
Hallo Zusammen,
ich bin neu hier im Forum, stelle mich mal kurz vor, mein Name ist Jörg, komme aus Wesel am Niederrhein, habe schon 2 Preamps, diverse Effekte und Switchsysteme gebaut ( Loops etc) bin vom Beruf Elektroinstallateur und Medizintechniker, mittlerweile in Rente.
Mich interessieren besonders Racksysteme aus den 80ern, dieser LA Studio, Live Sound, und mag diesen Sound und Spielweise von Steve Lukather, Dann Huff, Michael Landau, Michael Thompson etc.
ich plane ein neues Projekt zum Winter hin, möchte gerne den Kasha Rockmod II aufbauen, zumindest die beiden Zerrkanäle. Nun habe ich hier im Forum einen Schaltplan gefunden, wollte zunächst wissen, ob Dieser plausibel ist, also korrekt.
Ich hoffe, dass ich hier mit meinem Beitrag in der richtigen Rubrik bin, ansonsten bitte einfach verschieben.
Über Nachrichten würde ich mich sehr freuen.
Jörg
#89
Tech-Talk Design & Konzepte / Antw:NFB hinzufügen
Letzter Beitrag von Helmholtz - Nov 03, 2026, 04:46
Das ist ein "self-balancing floating Paraphase" PI mit zusätzlicher Kathodenkopplung.
https://www.valvewizard.co.uk/paraphase.html
Die Verstärkung kommt von der ersten Triode, die zweite invertiert nur das Anodensignal der ersten, hat also eine Verstärkung von möglichst genau 1.
Der naheliegende NFB Einspeisepunkt wäre die Kathode der ersten Triode.
Problem hier ist die Kopplung der beiden Kathoden, denn das NFB darf nur auf die erste Triode wirken.
Die Kathoden müssen also zumindest für AC entkoppelt werden.
Hier ist ein Beispiel:
https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_B-12N.pdf
#90
Letzter Beitrag von carlitz - Nov 03, 2026, 03:06
Oder am Punkt X einschleifen
