50w highgain amp mod
  • 123 Antworten
  • 57678 Aufrufe
Offline dukeamps
  • 182
Re:50w highgain amp mod
« Antwort #75 am: 16.12.2010 14:37 »
Hi stone, just tried that & it sounds good, only had a B500k pot, would you also leave the 68k out? Just have to get some mids, sounds a bit too scooped, i think i will lower that 1000pf see what happens. With that mod the amp is not as loud as the #34 mod which is better, you don't have to use a power soak.
Nigel
Stone
« Antwort #76 am: 16.12.2010 20:10 »
Hi Nigel
Thanks for the info - I am thinking it over to give it a try and it seems to be worth it.
Regards, Stone
Offline dukeamps
  • 182
« Antwort #77 am: 16.12.2010 20:28 »
Hi stone, no problem, just tweaking it a bit myself. Changed the 2k7 over so that it come first & then the 10k, sounds a bit more open, before the 500k pot i have put a 470k/500pf. Might put a bright cap on that 500k pot.
Nigel
Offline dukeamps
  • 182
« Antwort #78 am: 16.12.2010 20:49 »
Hi stone, I have took the 470k/500pf out didn't like it. It would be nice if you also tried the mod, then we could both compare our results.
Nigel
Stone
« Antwort #79 am: 20.12.2010 08:36 »
Hi Nigel
Sorry for answering late - maybe I have a chance to do some recordings and mods this week; got a new idea for better quality recordings and will have a look if it works.
Regards, Stone
Offline dukeamps
  • 182
« Antwort #80 am: 20.12.2010 14:46 »
Hi Nigel
Regards, Stone
Hi stone, no problem, looking forward to your results.
cheers :)
Nigel
Offline holgar
  • 6
« Antwort #81 am: 31.12.2010 19:13 »
Hi Stone,
I am glad to see, that you are back in business again.
Tweak on!
Best regards
Holgar
Stone
« Antwort #82 am: 12.01.2011 10:06 »
Hello
Thanks, Holgar :)
@Nigel: sorry, but currently I do not find any time going on and still I do not have done any further recordings. I think it will last some more weeks until working on tube amp circuitry again :(
Regards, Stone
  • 5.813
« Antwort #83 am: 12.01.2011 10:21 »
Here's a 50 Watter I've modded lately - it was completely modded by Finkenhäuser long before (+ clean channel, + loop, + anode-follower-4stages).
The clean and loop are very cool and well made IMO, the 2nd channel just had a bit too much of everything and lacked some dynamics, a pure lead channel, not a heavy cruncher, so . . . .
I've built that back into 3+CF with "my stuff" and a (soft) depth - I was trying to get back the typical Marshall flair, but with more bottom end and a more modern, meaty gain structure.
The clean channel recording hisses - was my fault, the mic pre had the HiZ setting . . .
http://www.youtube.com/watch?v=CcayuqKpI_Q
Input-R: 1K
150k Plate/1k5,2µ2 Cathode/4n7 - 470k+150pF - Gainpot (250klog)
100k Plate/2k7 Cathode/4n7 - 470k/470pF/470k(g)
100k Plate/820R Cathode
« Letzte Änderung: 12.01.2011 10:51 von Duesentrieb »
Stone
« Antwort #84 am: 12.01.2011 12:23 »
Hi Olaf
Sounds good. Interesting detail: I found a 2µF (yes I know you are using 2µ2) across a 1k5 in combination with 150k plate very suitable for an amp of a friend of mine ... it is pretty close to your mod as I have used a 22nF between stage 1 and 2 and used a 2n2 between stage 2 and 3.
From my point of view this adds a bit more meat to the solo sound / lines but the overall sound is a bit more compressed then.
Regards, Stone
  • 5.813
« Antwort #85 am: 12.01.2011 13:07 »
Not if you keep the coupling caps' values low and the gain pot's value lower than 500k, Stone ;)
Stone
« Antwort #86 am: 12.01.2011 14:16 »
Olaf,
I know, but the aim was to have a certain amount of compression ;) So I decided to use that big one as first coupling cap ... :) ... and to keep the other values, too (e.g 1M gain).
Regards, Stone
« Letzte Änderung: 12.01.2011 14:29 von Stone »
Offline Räuberpistole
  • 209
« Antwort #87 am: 12.01.2011 17:26 »
hi,
@ olaf: what values did you use for your "soft depth"?
btw. very interesting thread... again    :bier:
best regards,
tobi
In love with `DIY´
  • 5.813
« Antwort #88 am: 12.01.2011 18:07 »
A 4n7 and just a 250k log pot, gives much better (finer) results and makes it easy to add just small amounts of these 100Hz (or so).
Stone
« Antwort #89 am: 12.01.2011 19:16 »
Olaf,
concerning depth ... do you remember how much it was dialed in during recording? I know about its function and did use it on 4x00 Marshalls, but I never needed it with the older MVs oder SLPs because I think they 've got enough punch and bottom even with high gain "enabled".
Meanwhile I own a SLO100 clone and the added depth mod on that amp does make pretty much sense, which I did not expect to be necessary, but it is.
Regards, Stone
