#36 mod
  • 79 Antworten
  • 31964 Aufrufe
Offline dukeamps
  • 182
#36 mod
« am: 17.03.2011 09:27 »
Hi Guys, i have took the schem of the net, because it might be too dangerous for some people, because of the hot shield, i hope you understand :)
cheers
Nigel
« Letzte Änderung: 23.03.2011 09:45 von dukeamps »
Offline snyder80
  • 433
Re:#36 mod
« Antwort #1 am: 17.03.2011 12:51 »
Hello Nigel!
Thank you for sharing your work on this Mod.  :guitar:
Although your schematic is revision "6847" does it correspond to the "AFD tone 26 new" -clip you posted in the other thread?
I hope so, because it sounds quite nice and much better than the gainstructure in "AFD tone 68No3" clip...
Greetings,
snyder80
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #2 am: 17.03.2011 13:05 »
Hello Nigel!
Greetings,
snyder80
Hi snyder80, if you want the 26 new tone, just put 820r.47 on the third stage, & a 220p over the first plate resistor, but you might like it without the 220p, but i think 2k7.47 is more raw sounding, i havent done a clip yet, because they all sound something the same, also put the 150k on a switch, so you can turn it off for more gain :)
cheers
Nigel
Offline snyder80
  • 433
Re:#36 mod
« Antwort #3 am: 17.03.2011 13:13 »
Thank you for the specs!
One more thing about the 68 No3 clip: I think there was at leat one stage overdriven too much. It sounds like there could be some blocking distortion from the preamp (i.e. 820E II with too big CK?).
So does your "clip numerlogy" belong to different settings in the same circuit or does it mean different revisions of the mod itself (change in bypass caps/gridstoppers/voltage dividers between stages...)
Greetings,
snyder80
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #4 am: 17.03.2011 13:18 »
Greetings,
snyder80
i cant remember for sure what 68 no3 was, but it was probably without the 150k,
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #5 am: 17.03.2011 13:24 »
listening to the clip again,i remember again, i was testing what the amp sounded like with a smaller bypass cap on the first stage, so on that clip i done something crazy & put a 2k7.1 stage as the first stage, & thats how it sounds, not very nice :(
Offline snyder80
  • 433
Re:#36 mod
« Antwort #6 am: 17.03.2011 13:38 »
Hey Duke!
lets call No68 squishy and thin...
So obvious your clip numbering belongs to different revisions of mods. Nr.28 was also nice sounding. A little more open/airy in the Mids but maybe not that punchy or raw.
And at last one question: What are your settings for GVTMBP? Did you dial the Tonestack @noon (or same setting) for all the clips -or the way you suggested/posted in the 50w mod thread?
Greetings, snyder80
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #7 am: 17.03.2011 13:57 »
Hey Duke!
Greetings, snyder80
setting for all the clips, were g1 7, g2 6, mv4, t6, m5, p6, if you use the 150k you will maybe have to turn g1 up a bit,
28 was just 820r.68 on the third stage :)
Offline Räuberpistole
  • 209
Re:#36 mod
« Antwort #8 am: 17.03.2011 14:02 »
Hi Nigel,
thank you very much for sharing.
i guess i´ll give it a try next week - sounds really superb  :bier:
In love with `DIY´
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #9 am: 17.03.2011 14:09 »
Hi Nigel,
no problem, post a clip :)
Manfred
Re:#36 mod
« Antwort #10 am: 18.03.2011 22:22 »
Hi Nigel,
in my opinion the amp sounds awesome.
Do you have a voltage chart for it?
Manfred
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #11 am: 18.03.2011 22:43 »
Hi Nigel,
Manfred
Thanks Manfred for you feedback :) no sorry i havent.
cheers
Nigel
Offline dukeamps
  • 182
Re:#36 mod
« Antwort #12 am: 22.03.2011 15:57 »
Hi Guys, here is a new clip :)   http://soundclick.com/share.cfm?id=10426521
cheers
Nigel
ps here is the same clip with a bit of post eq    http://soundclick.com/share.cfm?id=10426993
« Letzte Änderung: 22.03.2011 17:45 von dukeamps »
Offline AmpGuru
  • 252
Re:#36 mod
« Antwort #13 am: 22.03.2011 18:13 »
what is the "hot shield" good for ? Is this supposed to be some kind of capacity coupled feedback ?  ;)
Or is just for bringing fun to the input jack modifier ?
AmpGuru
  • 2.461
Re:#36 mod
« Antwort #14 am: 22.03.2011 18:43 »
This.
Cheers Stephan
