LM3914 chip????
  • 16 Antworten
  • 9683 Aufrufe
rico
LM3914 chip????
« am: 26.04.2005 22:38 »
Hi guys. Maybe someone can help me - for what LM3914 chip is used in the dual rectifier, where should i connect it?
Thx
Offline TubeLeo
  • 323
  • Kauft nie einen Flextone "sch... Teil"
rico
Re:LM3914 chip????
« Antwort #2 am: 30.04.2005 16:15 »
i don't think this is corret, cause this chip is not even connected to any of the tubes, it's near the footswirch din.
it's for somethimg else and no one knows exactly fo what. i have already heard 5 different variants, and they're all wrong:(
Offline Stephan G.
  • 768
  • Yeah!!
Re:LM3914 chip????
« Antwort #3 am: 30.04.2005 17:22 »
Hi, Rico!
Forget the stabilization - The Chip normally is used for LED-Dot-/-Bargraph-Displays. It contains a 10-step-voltage-divider and is probably working as a Converter for the footpedal!
The analogue signal from the footboard can be converted to a digital signal - its like a 10-step-comparator.
For further information look at the datasheet:
http://www.national.com/pf/LM/LM3914.html
PLAY LOUD!!
Offline TubeLeo
  • 323
Re:LM3914 chip????
« Antwort #4 am: 2.05.2005 09:37 »
Hmm
Sollte das nächste mal vielleicht zuerst den Plan ansehen ..,
Nichts für ungút  :-\
rico
Re:LM3914 chip????
« Antwort #5 am: 3.05.2005 13:14 »
Okay, so is it in an AMP, or it is in a FOOTSWITCH?
Cause all i can see on the schemtic - only a few pins of LM chip are used and connected to somewhere... Is it normal?  :-[
rico
Re:LM3914 chip????
« Antwort #6 am: 5.05.2005 07:34 »
Someone, please, HELP!!! :'(
rico
Re:LM3914 chip????
« Antwort #7 am: 15.05.2005 20:41 »
PEOPLE HEEEEEEEEEEEEEEEEEEEEEEEEEELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SOS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'(
Offline Hannes
  • 932
Re:LM3914 chip????
« Antwort #8 am: 16.05.2005 00:27 »
Hi Rico!
Have you already studied the supplied data sheet?
According to my schematic only Pin #1, #18 and #17 are used, these are LED-driver pins. They are connected to the FX-selector-switch and switching matrix fpr ch.-selection.
Pin #5 is used as input, Pin #4 and #6 are used for reference voltage.
Maybe the footswitch supplies a positive or negative voltage to Pin #5 according to the selected channel?
And by the way: If no one answers it's because no one knows the answer - so stop bugging.
Best regards
Hannes
bäri
Re:LM3914 chip????
« Antwort #9 am: 16.05.2005 00:49 »
wo bleiben denn hier eigentlich unsere vielen "Recto"-Spezialisten (u.a. Killigrew,Guido u.s.w.)? Oder trauen die sich vielleicht etwa nur nicht wg. der engl. Sprache? :o :-X :-[
Günter
Offline Hannes
  • 932
Re:LM3914 chip????
« Antwort #10 am: 16.05.2005 01:19 »
Ich finde, dass der LM3914 sehr sonderlich eingebaut wurde - erscheint mir fast sinnfrei... ;)
Andererseits wäre es wohl kein Problem mit ein paar CMOS-Bausteinen das Switching neu zu bauen.
Hannes
rico
Re:LM3914 chip????
« Antwort #11 am: 16.05.2005 10:15 »
Hi, Hannes.
 Can youn tell me, the LM3914 chip is in a footsweitch, or it's on a PCBoard in an amp?
Offline Hannes
  • 932
Re:LM3914 chip????
« Antwort #12 am: 16.05.2005 10:45 »
Hi rico!
No, I can't tell you where the LM3914 is situated. But does it matter?
Best regards
Hannes
rico
Re:LM3914 chip????
« Antwort #13 am: 16.05.2005 11:53 »
I really dont' know, i'm asking because if it's not in an amp, i will forget about it untill i start making a footswitch, and if it IS in an amp, i need to have some place on a PCB for it. So...
I also wanted to know, how many contacts are connected to the footswitch DINm i know it's a 7pin connector with a 8-th in the center of it, but on the schematic u can only see that pin #7 is used.
And also, i can't find where to connect the 1'BUS wire.
Can ya help me with this? Thank you!
rico
Re:LM3914 chip????
« Antwort #14 am: 22.05.2005 01:09 »
HELLO?!??? ???
