LED spielereien, funktioniert das?
  • 6 Antworten
  • 4590 Aufrufe
Offline ludo
  • 51
« am: 27.09.2011 17:48 »
Hab da was gefunden...
The schematic below shows a simple preamp (albeit with some Valve Wizard tricks incorporated) and shows some fun ways in which LEDs can be incorporated, usually with no impact on the tone of the amp. The different applications are numbered:
1: In series with the anode. For normal values of anode resistor, this will have no effect on tone / operation. The LED will slowly come on as the valve warms up.
2: LED bias. Obviously this has the same effect as a bias resistor with a perfect bypass capacitor, so carries tonal considerations. The LED will slowly come on as the valve warms up.
3: In series with a cathode load resistance/tail resistance. Although this will raise the cathode voltage by a tiny amount, it is usually insignificant in terms of normal circuit operation. The LED will slowly come on as the valve warms up.
4: In series with a smoothing capacitor. A rectifier diode is also added in parallel to allow normal operation of the cap. The LED will be off normally, but will light up as the capacitor discharges at switch off, providing a warning while the cap is still holding charge
5: A dual-colour LED in series with a smoothing capacitor. The green LED will light for a couple of seconds at switch on as the capacitor charges, and the red LED will light at switch off. Don't use this one on the reservoir cap though, the higher inrush current will fry the LED!
6: Ok, this one isn't an LED, it's a neon lamp used as grid-to-cathode arc protection on a DC-coupled stage. The neon will light at switch-on until the valve has warmed up, when it will switch off. (An LED can't be used here due to the high reverse-voltage during normal operation).http://www.freewebs.com/valvewizard2/ampwithLEDs.jpg
Offline Han die Blume
  • 906
Re: LED spielereien, funktioniert das?
« Antwort #1 am: 27.09.2011 19:34 »
Hi lieber Ludo,
Ja.
LG
Kai
Offline tubeampgrufti
  • 589
« Antwort #2 am: 28.09.2011 09:00 »
Dass das zumindest halbwegs funktioniert bezweifle ich auch nicht, aber wenn jetzt einer auf die Idee kommt, das in seinen bestehenden Amp einzubauen, wird er sich doch wundern, wie in erster Linie die LED "2" in der Kathode der V1 den Sound beeinflussen wird. Auch die Dioden bei den Sieb-Cs werden einen (kleinen ?) Einfluss auf den Glättungsfaktor haben. Wenn ich keinen Ueberlegungsfehler mache, dann wird die "Brummspannung" um die Summe der beiden jeweiligen Diodenspannungen (LED je ca. 1,5 V) über die periodische "Lade/Entladephase" erhöht. Das ist an einer Vorstufe dann schon ganz heftig! Hängt aber wohl davon ab, mit welchem Ripple die Spannung an den Siebwiderständen jeweils ankommt.
Bitte korrigiert mich wenn ich falsch liegen sollte! ???
gruss
bruno
  • 906
« Antwort #3 am: 28.09.2011 10:03 »
Das hab ich ausprobiert. Dadurch bekommt man wunderschöne runde Bässe die für clean sehr geil sind. Der Nachteil ist, dass ein evtl. 50Hz-Brummen nicht gedämpft wird durch den fehlenden Kathodenelko und dass es vielleicht etwas zuviel des guten ist, wenns stark Richtung Lead-Sound gehen soll, aber da kann man noch an dem ersten KoppelC drehen.
Von den anderen LEDs erwarte ich keine großen hörbaren Unterschiede - ich denke, dass vielleicht das Netzteil insgesamt etwas weicher wird.
lg
Kai
« Antwort #4 am: 28.09.2011 11:20 »
ich hab das mal an einem vierstufigen Netzteil (Anoden, Screens, PI, eine Preampröhre) durchsimuliert, einmal am PI-Siebelko, einmal am letzten. Man sieht, dass zumindest in der simulierten Netzteilkonfiguration das Einbringen von Dioden einen erheblichen Einfluss hat. Anbei die Bilder der Simulation, einmal am PI, einmal an V1. Grün ist ohne, blau mit Dioden. Am PI sieht man, dass die Brummspannung sich auf stattliche 1,2V p-p erhöht, was man deutlich hören dürfte, oder? Am vierten Siebglied sehen die Kurven erstmal ähnlich aus, das ganze spielt sich aber in einer ganz anderen Dimension ab - mit Dioden gibt's 20mV Brummspannung, vorher war der Knoten ja quasi brummspannungsfrei. Ob man das hört...? Könnte ich mir vorstellen.
  • 589
« Antwort #5 am: 28.09.2011 13:49 »
Danke euch, Nils und Kai!
So in etwa habe ich das erwartet. Was das nun für die Amp-Praxis dann bedeutet kann sich ja jeder, der damit Erfahrung hat, in etwa ausmalen.
Das mit dem "runden Bass" beim Cleansound habe ich mir mal schon gemerkt und werde ich mal bei einem Cleankanal bei Gelegenheit ausprobieren. Interessant jedenfalls!
grüsse euch
bruno
Offline ludo
  • 51
« Antwort #6 am: 30.09.2011 16:20 »
Danke für die Antworten!
LED 2 werd ich evtl ma probieren...
Gruß Ludo
