10'' Eminence Identifikation?
  • 4 Antworten
  • 5062 Aufrufe
Offline MeMyselfAndI
  • 52
« am: 21.11.2014 12:34 »
Hallo Leute,
kann man sagen, dass es sich bei einem Eminence ohne übliches Label um einen Legend 1058 handelt, wenn seitlich "EM10-758" und daneben kleingedruckt: "10449 8 Ohm  67 - 92410116 G3" steht?
Gruss,
Peer
Offline DerDomze
  • 363
Re: 10'' Eminence Identifikation?
« Antwort #1 am: 21.11.2014 13:31 »
könnte das ein Tippfehler sein...
bei
Zitat von: Eminence link=http://www.eminence.com/support/faq/
The Eminence speaker that I have is not on the website. What's its model number?
If you don't see your speaker listed on our website, then it is one that we "custom-made". Until January 2000 when we debuted our own "Genuine Eminence" distribution line, Eminence Speaker only made custom designed speakers for companies who loaded them in cabinets or sold them as "raw" drivers. We don't assign model numbers to custom speakers. All of our OEM speakers are identified by their spec number. We attach a small label to either the side of the magnet or the inside one of the basket arms with our spec number and manufacturing/date code on it. The spec number will begin with the size of the speaker (i.e. for a 10" it would be 101123). The manufacturing/date code number is as follows:
EIA# for ESC   Year   Week    Serial #   Metal Group
67   -01   12A   0217   G1
The "67" tells you that the speaker was built by Eminence, the "01" indicates that the speaker was built in 2001, and the "12" means it was built the 12th week of the year.
demnach:
67 -
year: (19)92
week: 41
Serial #:0116
Metal Group: G3
das ME10-758 würd ich mal Raten: 10(Zoll) -75(W) 8(Ohm) (ich hab vergleichsweise einen"ME10-1008" hier warens halt 100W im Datenblatt)
ein Foto von Kalotte und Magnet könnte bei der Identifikation auch gut helfen.
« Letzte Änderung: 21.11.2014 13:35 von DerDomze »
current Projects:
- "JarOfDirt" SüpersonicBausatz (vor Endverdrahtung)
- JMP 2203 6550 + Depth
- TScreamer, Phase90, Riot, OCD, GreenRinger, SmallClone
Offline DerDomze
  • 363
« Antwort #2 am: 21.11.2014 13:58 »
Google hat grade was interesantes gefunden hier ein Zitatz aus dem Party-PA Forum
Zitat von: Sabbelbacke
Eminence hat die EM-Serie nur in Europa verkauft, das ist auch schon eine Weile her (10-15 Jahre oder so). Hab auch noch einige davon im Regal oder älteren Speakern drin. Leider sind die Modelle immer wieder verändert worden (und das teilweise heftigst): Sollte man also noch Angaben finden (ich habe unmengen an Katalogen noch hier), so stimmen die Daten evtl. also nicht. Ausschallgebend sind nämlich die kleinen Zahlen und Angaben auf den grauen Aufklebern am Magneten. Schreib Eminence in USA direkt an, welche Paremeter das Chassis exakt hat. EM10-100 als Angabe reicht nicht.Bild
Anthony Lucas hilft besimmt gerne weiter:
anthony.lucas@eminence.com
current Projects:
  • 52
« Antwort #3 am: 21.11.2014 15:15 »
Aha, ist ja interessant!
Danke, Domze!
Der Speaker ist (noch?) nicht meiner. Deshalb habe ich nur 2 Fotos vom Anbieter.
Hier sind die zwei Fotos:
« Letzte Änderung: 21.11.2014 15:17 von MeMyselfAndI »
  • 52
« Antwort #4 am: 24.11.2014 14:31 »
:topjob: So, ich habe bei Mr. Lucas angefragt und das hier ist das Ergebnis:
Hi Peer,
10449 was a custom designed OEM speaker that we manufactured to one of our customer's specifications.  It is an 8 ohm speaker with a 1.5" voice coil and a 30 oz ceramic magnet.  We do not rate OEM designs (that is left up to the customer to test and rate their cabinet or amp), but a conservative thermal power rating based on the voice coil diameter would be about 75 watts.  Here are the T/S parameters:
05-RE OHMS    7.35         13-FS HZ      40.66
06-LE MH       .75         14-MMS GMS    18.70
07-QM         5.07         15-CMS mm/N    .8179
08-QE         .360         16-RMS NS/M    .9437
09-QT         .340         17-VAS LTRS   136.64
10-XMAX MM    .50          18-SD SCM     344.88
11-BL TM     9.87          19-EBP       112.7
12-EFF %     2.45          20-SPL dB     95.9
This speaker is more like our Alpha-10A, which is a pro audio midbass woofer.
Best Regards,
Anthony Lucas
