an help for the Lndverb standalone
  • 25 Antworten
  • 10224 Aufrufe
Offline krave
  • 13
« am: 19.04.2015 18:03 »
I can't understand german but I hope in a help anyway.
I'm building a standalone reverb with the lndverb kit and I have this kind of problems: the dwell pot acts like a volume and goes from "silence" to "satured high volume", the mix pot doesn't mix at all, it only gives a little space but the sound that comes out it's alway only with full reverb. Even when the the dwell pot is to 0 (and no sound comes from the guitar) if I pat the tank I have the tank "sound".
In short it seems that there is no clean sound from the instrument but only wet and the pots they do not behave as they should.
Thank you
Andrea
Offline sev
  • 853
Re: an help for the Lndverb standalone
« Antwort #1 am: 19.04.2015 18:39 »
Hi Andrea,
try pasting some photos, maybe there is a visible fault.
greets
Sev
--Edward Murphy
Offline krave
  • 13
« Antwort #2 am: 19.04.2015 19:09 »
Hi Sev
the blue switch on the right is a 3pdt I want to use for a true bypass (the led, in the middle poles, isn't in place yet).
the yellow wires are all to ground.
there is a little bit of confusion now because I'm solding and de-solding everything...
« Antwort #3 am: 19.04.2015 19:24 »
i think the VPUMP does not bring enough current for this application!
Offline krave
  • 13
« Antwort #4 am: 19.04.2015 19:37 »
this would be strange because istructions recommanded to use the Vpump
« Antwort #5 am: 19.04.2015 19:44 »
« Antwort #6 am: 19.04.2015 20:11 »
The VPump works fine for this kit.
Please remove the bypass switch and build the standalone unit as documented. You can add further options when the unit works but first you should build the "good" version.
Also check the voltages to make sure that you have not killed the VPump.
Check the wiring of the potentiometers, the values of the potentiometers and the orientation.
Best regards, Dirk
Offline krave
  • 13
« Antwort #7 am: 19.04.2015 22:19 »
I tried with the plain project, without true bypass, without footswitch... but it's just the same: the dwell pot works as a volume (from no sound to crunch) and the mix give a bit more of space but no chance to have dry sound.
the pots value it's ok, the voltage it's 200vdc, the wiring it's ok but nothing changes.
I don't know what to try now...
« Antwort #8 am: 19.04.2015 22:34 »
sounds like that the dry-path is dead. What values did you take for R13 and R52 ?
Best regards, Dirk
Offline krave
  • 13
« Antwort #9 am: 19.04.2015 23:12 »
470k for R52 and 1,5M for R13.
yes, there is no dry path and there is a strange behavior with the pot, because without drypath if I put the mix to 0 I should have no sound,
conversely it gives me more depth of reverb. And the dwell acts like a volume...
« Antwort #10 am: 20.04.2015 08:27 »
I do not know what you made wrong, maybe the bypass has killed a component or the soldering is not OK or what ever.
You can trace the dry-path starting from connection IN B to R13 and from R13 to MIX IN2. If you do not have a connection than you can remove the R13 and solder a wire from IN B to MIX IN2 with an 1M5 resistor in between.
That's all I can say.
Best regards, Dirk
Offline krave
  • 13
« Antwort #11 am: 20.04.2015 16:14 »
Dirk, you mean IN A for the standalone or am I wrong with my corrent input?
« Antwort #12 am: 20.04.2015 16:48 »
No, you Input is OK !!! Don't touch it.
For the connection: IN B to R13 and from R13 to MIX IN2
Dirk
Offline krave
  • 13
« Antwort #13 am: 20.04.2015 18:24 »
I have path from IN B to R13 and from R13 to MIX IN2. have I got to try with the direct (IN B to MIX IN2 with 1M5) anyhow?
thank you
Andrea
« Antwort #14 am: 20.04.2015 20:38 »
thank you
and the Resistor is OK ?
Dirk
