Impressum |
Datenschutz |
Shop |
DIY |
TT @ Twitter |
TT-Cabs
Einloggen
Registrieren
Suche
Übersicht
Hilfe
Suche
Einloggen
Registrieren
Tube-Town Forum
Technik
Tech-Talk TT-Projekte
18 watt with choke?
« vorheriges
nächstes »
Drucken
Seiten: [
1
Nach unten
18 watt with choke?
7 Antworten
4032 Aufrufe
caliban
Jr. Member
20
18 watt with choke?
am:
13.04.2016 00:36 »
I might want to order an 18 watts (from tubetown) kit soon. I was wondering if you can recommend the use of a choke in the power supply (if so, which one would work best in this case), or if that might be overkill/irrelevant.
Thanks a lot
Athlord
YaBB God
3.229
Re: 18 watt with choke?
Antwort #1 am:
13.04.2016 06:56 »
Did the original Marshall 18W use a Choke? NO
It´s irrelevant.
caliban
Jr. Member
20
Antwort #2 am:
13.04.2016 10:02 »
Good point, but for instance the vox ac15 (which has quite a similar output section as the 18watter) does use a choke. (At least the handwired reissue ones.)
Dirk
Dirk M.
Administrator
YaBB God
12.953
2T or not 2T
WWW
Antwort #3 am:
13.04.2016 11:04 »
if you have a strong feeling that you need to use a choke than feel free to use a choke. You will not damage anything.
Best regards, Dirk
bluesfreak
YaBB God
2.654
Ain`t no tube, ain`t no sound....
Antwort #4 am:
13.04.2016 11:07 »
i tried a choke in my own 18W build and was not impressed, the Amp got too spongy and lost quite some of the gnarl so I switched back to the "normal" setup with a sag resistor...You will not harm anything when installing a choke but it will alter the behavior away from y typical 18W in an uncomfortable way...
just my 2c
blues
caliban
Jr. Member
20
Antwort #5 am:
13.04.2016 12:12 »
Thanks for your answers. I'll try without the choke, might still add one afterwards
. Which one did you use, bluesfreak?
bluesfreak
YaBB God
2.654
Antwort #6 am:
13.04.2016 13:37 »
I need to check but if I recall correctly it was a 3H or 4H Classic Tone Version I had flying around. Considering Voltages and Currents in an 18W this one should do the trick:
http://www.tube-town.net/ttstore/Transformatoren/Drosseln/Hammond-Guitar-Series/Hammond-194A-Drossel-Fender-125C3A-022707::2145.html?MODsid=o2a90d0acnp8d0m1dtn7d4cvj7
caliban
Jr. Member
20
Antwort #7 am:
15.04.2016 17:32 »
Thanks
Drucken
Seiten: [
1
Nach oben
« vorheriges
nächstes »
