I desperately need a custom made chassis... anyone know where to get one?
  • 3 Antworten
  • 4169 Aufrufe
Offline Gtr0
  • 7
Hi Folks.
I seriously need a custom made chassis as I am designing a multi-channel high gain amplifier. My lack for foreign languages doesn't help, for sure (american living in belgium). The big problem I need to overcome is the chassis height... I need something closer to 8.5cm rather than the usual 6.5cm.
Does ANYONE have a clue where I can have a "prototype" chassis made with the possibility of more in the future?
Any help is appreciated!!!
Gtr0
Offline LöD
  • 2.348
I'd suggest to go to a local locksmith who can bend sheet metal. It shouldn't be a problem to get a chassis this way in exactly the dimensions you need it
LöD
Offline Gtr0
  • 7
LöD
Thank you. I will check it out right away.
Best Regards,
Gtr0
Offline geowicht
  • 399
local locksmith are an option but mostly they can/will only produce raw chassis at reasonable costs and you need to punch/drill the holes by your own.
You could also try companies that laser cut and bend chassis. This is usually quite expensive for prototypes, but as soon as you order a series it may get much cheaper per unit. The problem is to deliver the necessary 3-D dataset (CAD) that they can use for their processing (compatible to their software) otherwise these are probably additional costs. I once asked one of these laser companies and they gave me a quote of more than 200€, far to much for a single chassis for my hobby, but may be ok for (semi-) professionals when they order series of chassis on a reduced fee.
Good luck. I think there are many people here that appreciate your feedback for their own projects.
Gerhard
