Impressum |
Datenschutz |
Shop |
DIY |
TT @ Twitter |
TT-Cabs
Einloggen
Registrieren
Suche
Übersicht
Hilfe
Suche
Einloggen
Registrieren
Tube-Town Forum
Technik
Tech-Talk TT-Projekte
TT 18 watt problem
« vorheriges
nächstes »
Drucken
Seiten: [
1
Nach unten
TT 18 watt problem
3 Antworten
2430 Aufrufe
beniboy87
Newbie
1
TT 18 watt problem
am:
14.02.2018 09:13 »
Hi all,
I apologize that I'm writing in English, but unfortunately, my German knowledge is not existing
I have bought and built the Marshall 18 watt kit from this site and it works, but only when I'm below 6 on Volume. If I crank it up higher, I get this oscillation (?) problem.
Video of the problem:
https://www.youtube.com/watch?v=FirjbD_hppI
I tried to poke around with a wooden stick and touch things in the amp, but I could not find the issue.
Has anyone faced this issue yet, or do you have an idea, where should I look?
Thanks, folks!
geowicht
YaBB God
399
Re: TT 18 watt problem
Antwort #1 am:
14.02.2018 09:46 »
Hi, may be the link in this thread is helpful:
http://www.tube-town.de/ttforum/index.php/topic,15106.msg149054.html#msg149054
If not than please post schematic with your measured voltages and a clear pic of your built.
Gerhard
alexradium
Gast
Antwort #2 am:
14.02.2018 14:40 »
since there is no feedback,reversing output transformer wires does nothing.
most probably its a parasitic oscillation,it can be a wire too long or in the wrong position,a bad or missing ground point,a bad soldering.
Try separate the grid wires from the rest.
Check for continuity on all supposed ground points.
GeorgT
Sr. Member
114
Antwort #3 am:
14.02.2018 15:58 »
you connected something wrong, take some photos of your setup and put them in here
does something change if you turn on the middle regulator?
Georg
Drucken
Seiten: [
1
Nach oben
« vorheriges
nächstes »
