FX LOOP ( LND150) problem.
  • 10 Antworten
  • 3466 Aufrufe
Offline zanalog
  • 5
« am: 23.07.2018 12:59 »
Hi Iam Rafa from Barcelona.
Sorry but I don't speak German.
I have installed the LND 150 kit.
It's working, but I do not like the sound it gives me.
I have installed it in a marshall 2204. I have also installed the switch kit.
When the Loop is bypass, it sounds perfect but when it turns it on the sound becomes treble and GRSSHH.
From the beginning I have not installed the silver mica.
I tried to increase the capacitors and I had not expected the improvement.
I have also tried to remove R5 (feeback) but I have not gotten better either.
I have also installed a TRIMPOT on the input resistance to adjust signal.
Could someone give me an answer?
Thank you very very much
Offline guanre
  • 148
Re: FX LOOP ( LND150) problem.
« Antwort #1 am: 23.07.2018 14:16 »
Bon dia Rafa,
you have chosen the right input level?
Input Levels:
InA: 30 - 60 Vpp, max. 65 Vpp
InB: 10 - 15 Vpp, max. 18 Vpp
  • 12.953
« Antwort #2 am: 23.07.2018 15:29 »
Please post a schematic of the installation and some pictures of your build. Also some reference voltages would be great. The loop works perfect if used correctly so I guess you made a mistake with the build or the installation or both. Maybe some ground is missing or whatever.
Best regards, Dirk
Offline zanalog
  • 5
« Antwort #3 am: 23.07.2018 16:01 »
Bon dia Rafa,
Input Levels:
yes I put a trimpot in the input level resistor to adjust de level. its Sound treble anyway.
I am drawing the layout to show you Dirk but I use the layout from datasheet of the kit.
(Sorry for my english)
  • 12.953
« Antwort #4 am: 23.07.2018 16:10 »
Not the schematic of the kit but where you have installed the loop in the amp, also reference voltages would be helpful, some pictures and a trace of the signal if possible. Also check all ground connections and make sure that the loop has a good ground connection too.
Best regards, Dirk
Offline robert_do
  • 6
« Antwort #5 am: 23.07.2018 21:50 »
maybe you mixed the send and return level pots by accident (one is 100k and one 500k)? I did and in my case it sounded similar to your description.
Best regards
 Robert
Offline zanalog
  • 5
« Antwort #6 am: 26.07.2018 11:05 »
Best regards
 Robert
no its ok.
This is my Voltage Reading
Algernon Charles Swinburne A Cameo
  • 12.953
« Antwort #7 am: 27.07.2018 08:21 »
The voltage seams to be OK.
Do you use the loop serial or parallel ? It looks like that it has a serial connection but hard to tell. There are too much wires on the picture.
Best regards, Dirk
Offline zanalog
  • 5
« Antwort #8 am: 30.07.2018 17:12 »
Best regards, Dirk
Serial
I don't know What I can do it.... it's Sound more treble
Offline zanalog
  • 5
« Antwort #9 am: 30.07.2018 17:49 »
The problem is in the SEND.
I conected the output wire of the PCB to SEND jack. And the treble appears.
365V is high?
  • 12.953
« Antwort #10 am: 31.07.2018 10:23 »
That means that the Loop itslef is working fine but you have a problem in your chain or with the ground.
Best regards, Dirk
