TT LummerLand ecc99 biasing Help
  • 1 Antworten
  • 1499 Aufrufe
Offline Leadman
  • 52
« am: 25.04.2020 13:12 »
Hello,
In the schematic from TT Lummerland the power amp section is biased with two 560R resistor for a 12au7 Tube.
I Want to run the Lummerland with a ecc99, I have a Tube Town 30VA toroidal transformer and a TT 10watt ec99 output transformer (15k OT impedance).
In the other low TT plans, we can see that ecc99 is biased as follow  (with same +B voltage):
- Low Molly 270R+100uf cap
- Low Wild 13 330R+47uf cap
- Low Emma 2x560R resistors
- Low hot Lukas 330R+47uF
What config would I choose for better perfomance in my plan? Should I leave the same bias setting for ecc99 and 12au7 tubes?
Best Regards from Spain.
Offline Leadman
  • 52
Re: TT LummerLand ecc99 biasing Help
« Antwort #1 am: 29.04.2020 16:03 »
The emma 2x560R non bypassed cathode bias resistors runs fine for a ecc99 TT Lummerland with the 10watts OT, it set the bias about at 88% dissipation, not so far from 100% recommended for cathode bias in pentodes.
