wiring of 6,3mm Jack input sockets
  • 1 Antworten
  • 2472 Aufrufe
Offline kentuckytukker
  • 92
« am: 29.05.2020 13:30 »
Hi amp. builders,
To solder the parts on the 6,3mm input sockets for my amp. projects I always first mount these sockets on the outside of the chassis and then solder the resistors and required bridge wires. After completion I remove the whole set  and relocate them to the inside of the chassis. For me it is proven to be the most simple way the create a neath way of wiring/soldering.
gr, René
the more you drink the WC
  • 92
Re: wiring of 6,3mm Jack input sockets
« Antwort #1 am: 29.05.2020 13:45 »
And here a 3D schematic diagram for extra clarification. This is the way HiWatt wires the sockets in their amps. Courtesy of MH
