Started another AC18
  • 19 Antworten
  • 3550 Aufrufe
Offline JimR
  • 9
« am: 22.01.2022 14:57 »
My first amp build, after making 2 15" Celestion Fullback cabinets (one for each lockdown!) I really want another AC18 to get a full stereo setup. I know it's cheating to have a working AC18 but I need all the help I can get! BTW, my old AC18 (AC18 #002 Dual Rectifier) has tube and solid state rectifier, the new kit only has tube.
Wish me luck...
/JimR
Sorry for the English, you can answer in German
Offline JimR
  • 9
Re: Started another AC18
« Antwort #1 am: 23.01.2022 18:14 »
Yess, it worked the first time, awesome!!  :bier:
https://youtu.be/J6J0ji1pWrk
/JimR
« Letzte Änderung: 23.01.2022 18:19 von JimR »
Offline haebbe58
  • 3.539
« Antwort #2 am: 24.01.2022 16:31 »
 :topjob:
Offline Laurent
  • 2.029
  • Nichts ist unmöglich
« Antwort #3 am: 24.01.2022 17:57 »
Well done!
Offline Stubenrocker81
  • 1.105
« Antwort #4 am: 24.01.2022 18:48 »
 :topjob:
Sehr schön! Die Beinchen der Bauteile auf dem Turretboard noch gerade biegen 😉.
Vielen Dank für die schönen Bilder!
Zum AC18 gibt es auch viele Threads im Forum zu finden!
LG Stephan
LG Stephan
Offline JimR
  • 9
« Antwort #5 am: 5.02.2022 20:11 »
/Jim
  • 1.105
« Antwort #6 am: 6.02.2022 09:16 »
 :topjob:
Viel Spaß mit den beiden Amps!
LG Stephan
Offline JimR
  • 9
« Antwort #7 am: 15.04.2022 09:33 »
After the first couple of gigs with my two AC18 heads into UK Greenback cabs I am ready for some mods to increase the presence/topend of the heads. I am playing with CUT all the way up and still missing top end.
I can see you guys are recommending changing or removing C8, can you explain what C8 does in the circuit?
Also, I have ordered a selection of bright caps to test but I worry that I might lose the low end - I am using TONE position 2 (C5 1 nF) which has a nice fat bottom end.
Thanks
/JimR
  • 1.105
« Antwort #8 am: 16.04.2022 09:14 »
Hallo JimR
Ich habe C12 schaltbar gemacht.
3 Wege Toggle Switch.
Mitte = ohne Cap
Oben= 4,7 nf
Unten= 2,2 nf
Du kannst ja mal anstatt den 4,7nf einen 2,2nf einlöten.
Der Cap hat auch bei Cut voll auf noch Einfluss auf die Höhen. Teste es😉
Grüße Stephan
« Letzte Änderung: 16.04.2022 09:15 von Stubenrocker81 »
  • 1.105
« Antwort #9 am: 16.04.2022 09:18 »
Nachtrag!
Die Mallory Caps sind auch sehr dumpf! Den Phase Inverter mit Sozos aufbauen bringt auch mehr Höhen.
  • 3.935
« Antwort #10 am: 16.04.2022 11:16 »
Hallo Jimr,
meine Vorschläge:
  • Cut abschaltbar machen
  • Den kleinen C am PI raus
  • An der Eingangsröhre ein um schaltmöglichkeit des Bypass-C von 22µF auf 2µ2 einbauen....
  • 1.105
« Antwort #11 am: 16.04.2022 15:12 »
Hallo Jimr,
meine Vorschläge:
Hallo Jochen
Den C vom P.I. gegen einen Kerko tauschen geht auch.
Ganz ohne ist es recht fies.
Die Mallorys sind das eigentlich Problem meiner Meinung nach.
Grüße Stephan
Offline JimR
  • 9
« Antwort #12 am: 26.04.2022 19:14 »
I finally got the components and today I tested:
1. C12 (CUT cap) changed from 4.7 nF to 2.2 nF: I couldn't hear any difference
2. Then I also changed C8 from 100 pF to 33 pF: No difference
3. Then I also changed C1 from 22 uF to 10 uF: No difference
br
/Jim
Offline dimashek
  • 517
« Antwort #13 am: 27.04.2022 09:52 »
Ich habe mir in solchen einfachen Amps immer eine Treble-Picking stufe eingebaut. Also eine R||C vor dem Volume.  Ohne war es mir auch immer zu dumpf.
Verkleinert etwas das Gain, bringt aber schöne Presence mit.
Vom Toneschalter ein 270k || 220p (oder sogar 330p) in Reihe zum Vol Pot.
Und dann noch 470k Parallel zum Pot.
Wenn du auf mehr Gain verzichten kannst - 680k||100p vor einem 220k Pot...  (das ist dann meine lieblings-treble pick Stufe)
Aber dann wird der Tone-Schalter nicht mehr korrekt arbeiten, die Kondis müssten neu berechnet werden
edit: ein bright cap am Poti könnte auch schon reichen ;)
« Letzte Änderung: 27.04.2022 09:55 von dimashek »
Offline dimashek
  • 517
« Antwort #14 am: 27.04.2022 11:45 »
Da fehlt mir grade ein, da ist doch schon ein treble-pick im tone-switch (unterste position)  ... Ich sollte echt besser aufpassen  :facepalm:
Damit müsste es doch presence-genug klingen?
« Letzte Änderung: 27.04.2022 11:50 von dimashek »
