Spitfire with to much top-end
  • 2 Antworten
  • 1726 Aufrufe
« am: 25.05.2022 14:55 »
Hello Everyone
I've built a Spitfire, and luckily it sounds like it works.
The problem is it has way too much top-end. It's not because it lacks a bottom, but I can only just open the tone potmeter before the top end goes completely over edge, and when I set the tone to reasonable top-end, I think it lacks quite a lot of midrange. Does anyone have any ideas?
Best!
Chris
Re: Spitfire with to much top-end
« Antwort #1 am: 25.05.2022 22:22 »
C3 might be a good place to start. You could check with different values to get a feeling of how it affects the top-end.
Best regards, Dirk
« Antwort #2 am: 20.06.2022 14:10 »
Thanks, it worked. If I remove it, and open the tone potmeter completely, it sounds great. Not top-boost though, so maybe I'll experiment with some other capacitors over time. But right now, I have a hard time believing that it can get any better.
\c
