px18 check output impedance of the selector
  • 3 Antworten
  • 1488 Aufrufe
Offline guibo
  • 2
I got a working px18, Bias is set around 60mV, tested working well with a 2x5.6 ohms resistance in series (20w each) and quickly tested with a testing speaker (6ohm) and a guitar.
I have got a doubt about the impedance selector, how i can measure it to find the 4 ohms and the 16 ohms selection?
I have done some measure in AC and with the speaker plugged i get:
A) 6.6 Kohms ; 10V
B) 6.2 Kohms ; 11V (middle selection so the 8ohms selection)
C) 5.5kohms, 11.25V
So which one is the 4ohms?
Thanks for your help.
regards
Antoine.
Offline _peter
  • 1.925
Re: px18 check output impedance of the selector
« Antwort #1 am: 5.06.2022 20:18 »
Hi Antoine,
with the amp switched off, disconnected from mains and discharged caps:
Apply a low ac voltage (say 10V) across the primary of the output transformer (connect it to the plates of the output tubes).
If the speaker jack is a switching type that shorts to ground, insert a plug into the jack so the jack is open.
Read the ac voltage across the jack for each position of the impedance switch.
The lowest is 4 Ohms, second 8 Ohms, highest 16 Ohms.
The voltage in the 16 Ohms position should be around double the voltage in the 4 Ohms position.
Best,
Peter
Offline guibo
  • 2
« Antwort #2 am: 5.06.2022 23:23 »
Just done it, works perfectly ! its very low voltage but i was able to read the diff, so i found the 16 ohms selection :)
Thanks you, really appreciate the tip.
regards.
Offline _peter
  • 1.925
« Antwort #3 am: 6.06.2022 17:45 »
yes, the voltage is low because of the transmission ratio of the output transformer.
But for this purpose it is perfectly fine and safer than using a higher voltage.
Best, Peter
