LNDverb without OT ?
  • 7 Antworten
  • 1950 Aufrufe
Offline Pandjesbaas
  • 7
« am: 15.07.2022 22:15 »
Hello good people,
Would it be possible to use the LNDverb-kit to drive an Accutronics/Belton digital reverb WITHOUT the use of an OT?
Greets, Frits
Re: LNDverb without OT ?
« Antwort #1 am: 15.07.2022 22:16 »
Please do not do this.
Best reagrds, Dirk
Offline Pandjesbaas
  • 7
« Antwort #2 am: 18.07.2022 00:47 »
Best reagrds, Dirk
Thank you for your comment...
But why should it not work?
If I replace the OT with an appropriate resistor and use a coupling cap, shouldn't it do the trick?
Or am I missing out something?
Greetz, Frits
Offline carlitz
  • 1.723
  • never give up
« Antwort #3 am: 18.07.2022 10:47 »
If you do that, you will have a high voltage connection to your reverb tank.
There are other ways to handle this, please do seek information on the valve wizard website
Offline Pandjesbaas
  • 7
« Antwort #4 am: 19.07.2022 22:25 »
The high voltage will be separated by a coupling cap...
Offline haebbe58
  • 3.539
« Antwort #5 am: 20.07.2022 09:45 »
absolute fatal nonsens!
Offline haebbe58
  • 3.539
« Antwort #6 am: 20.07.2022 09:57 »
Maybe there is a misunderstanding
you do/must not have to use the lnd for driving a digital reverb. It is not like a reverb spring. The digital reverb unit is made for working in low voltage area and does not need a driver like a tube or a hi voltage FET together with an OT.  But you can use this unit like an effects unit.
It has to be matched adeqautely regarding the level and impedance and a coupling capacitor for DC  blocking, that is all. For that have a look at effect insert schematics. You can handle it like an external effects unit.
Regards
Herbie
Offline Pandjesbaas
  • 7
« Antwort #7 am: 21.07.2022 23:33 »
Is that so? Please enlighten me, oh sun of knowledge...
