Impressum |
Datenschutz |
Shop |
DIY |
TT @ Twitter |
TT-Cabs
Einloggen
Registrieren
Suche
Übersicht
Hilfe
Suche
Einloggen
Registrieren
Tube-Town Forum
Technik
Tech-Talk Amps
PT for 1U power amp
« vorheriges
nächstes »
Drucken
Seiten: [
1
Nach unten
PT for 1U power amp
2 Antworten
2818 Aufrufe
badomen
Jr. Member
20
PT for 1U power amp
am:
22.10.2008 22:41 »
hallo
I want to build power amp like marshall 20/20 or mesa boogie in 1U chassis with 2XEL84 ,and I want to use marshall 20/20 OT from TAD and Dirk's 50VA ringkern trafo for PT.
Question is ,can I use this trafo for my project,I thing yes but I'm not sure.
Dirk
Dirk M.
Administrator
YaBB God
12.935
2T or not 2T
WWW
Re: PT for 1U power amp
Antwort #1 am:
22.10.2008 22:58 »
the high of the T50 is 40 mm, 1 U is 45 mm - so it should work but absolutly at the limit.
Best regards, Dirk
harryhirsch
YaBB God
259
Antwort #2 am:
22.10.2008 22:59 »
the HT voltage should be fine for EL84. A tad high, but ok.
Heater current is enough, unless you put in several ECC83.
Volker
Drucken
Seiten: [
1
Nach oben
« vorheriges
nächstes »
