Question about fuses on the TT66 Mk2
  • 3 Antworten
  • 3959 Aufrufe
Offline Carruw
  • Newbie
  • 4
« am: 29.06.2012 13:42 »
My German is not what it used to be so I will write in English.
I have recently purchased the TT66 Mk2 and have started building it.
On the schematic there are two fuses but the chassis only have one mount. What do i do with the second fuse?
Thanks for helping.
/Carruw
  • 12.985
Re: Question about fuses on the TT66 Mk2
« Antwort #1 am: 29.06.2012 13:47 »
Hi !
The "second" fuse is the first fuse and it is between the mains and the primary of the power transformer. The Power Jack has an integrated fuse holder. Just use that !
http://www.tube-town.net/ttstore/product_info.php/language/en/info/p4458_Kaltgeraeteeinbaubuchse-m--Sicherungshalter--Snap-In.html
Offline kugelblitz
  • 1.724
  • be seeing you...
« Antwort #2 am: 29.06.2012 13:47 »
Hello,
I have not build any TT kits but, as far as i understand, put one fuse in the dedicated fuseholder (Heater of Rectifier GND) and the other one in the integrated fuse holder at the powerjack.
Hopefully someone who build this amp can check this hints.
EDIT: Too slow ;)
Regards,
Offline Carruw
  • Newbie
  • 4
« Antwort #3 am: 29.06.2012 13:51 »
I see, thank you very much for the fast replies.
Thanks for the help.
