Ok, on to the preamp heaters. Usually wiring up heaters is my least favorite part of building an amp. It's a pain in the ass. The normal way, I'll just throw some wire into the chuck of a drill and twist away. Then cut lengths as needed and bend and wire and weave it all together. Easier than doing it by hand, but still torture.
I was actually looking forward to doing the heaters on this build, though. Just some straight wire and you're done! Love it
If you've ever wondered how to get straight bus wire, this is how I decided to do it. I used an armorer's block that I use to strip down my 1911 and drilled an 18-20 AWG hole thru it. Then I put one end of the wire in a drill and "extrude" it through the block while the drill rotates. I move the block back and forth slowly and carefully until the wire is as straight as I can get it and/or until I get super bored. Then I'll roll the wire under a wine bottle on a flat counter a bit for good measure. Seems to do the trick. Just takes a while.
