18 watt with choke?‏
  • 7 Antworten
  • 4401 Aufrufe
Offline caliban
  • 20
« am: 13.04.2016 00:36 »
I might want to order an 18 watts (from tubetown) kit soon. I was wondering if you can recommend the use of a choke in the power supply (if so, which one would work best in this case), or if that might be overkill/irrelevant.
Thanks a lot :)
  • 3.230
Re: 18 watt with choke?‏
« Antwort #1 am: 13.04.2016 06:56 »
Did the original Marshall 18W use a Choke? NO
It´s irrelevant.
Offline caliban
  • 20
« Antwort #2 am: 13.04.2016 10:02 »
Good point, but for instance the vox ac15 (which has quite a similar output section as the 18watter) does use a choke. (At least the handwired reissue ones.)
  • 12.970
« Antwort #3 am: 13.04.2016 11:04 »
if you have a strong feeling that you need to use a choke than feel free to use a choke. You will not damage anything.
Best regards, Dirk
Offline bluesfreak
  • 2.670
« Antwort #4 am: 13.04.2016 11:07 »
i tried a choke in my own 18W build and was not impressed, the Amp got too spongy and lost quite some of the gnarl so I switched back to the "normal" setup with a sag resistor...You will not harm anything when installing a choke but it will alter the behavior away from y typical 18W in an uncomfortable way...
just my 2c
blues
Offline caliban
  • 20
« Antwort #5 am: 13.04.2016 12:12 »
Thanks for your answers. I'll try without the choke, might still add one afterwards :). Which one did you use, bluesfreak?
Offline bluesfreak
  • 2.670
« Antwort #6 am: 13.04.2016 13:37 »
I need to check but if I recall correctly it was a 3H or 4H Classic Tone Version I had flying around. Considering Voltages and Currents in an 18W this one should do the trick: http://www.tube-town.net/ttstore/Transformatoren/Drosseln/Hammond-Guitar-Series/Hammond-194A-Drossel-Fender-125C3A-022707::2145.html?MODsid=o2a90d0acnp8d0m1dtn7d4cvj7
Offline caliban
  • 20
« Antwort #7 am: 15.04.2016 17:32 »
