Impressum |
Datenschutz |
Shop |
DIY |
TT @ Twitter |
TT-Cabs
Einloggen
Registrieren
Suche
Übersicht
Hilfe
Suche
Einloggen
Registrieren
Technik
Tech-Talk Amps
doubling current with two parallel transformers.
« vorheriges
nächstes »
Drucken
Seiten: [
1
Nach unten
3 Antworten
1333 Aufrufe
Leadman
58
am:
8.09.2020 23:05 »
Hello
Is wiring two TT 50VA power transformers correct for build a 4xel84 style amp? I need the exact voltage that the TT 50Va put but I am thinking about build a pro junior style amp with 4xel84 for gigging in bigger pubs.
Best Regards.
dimashek
517
Re: doubling current with two parallel transformers.
Antwort #1 am:
10.09.2020 11:33 »
This will work only, if the transformers are exactly same! Same winding number in Primary/Secondary.
I would not try this
Leadman
58
Antwort #2 am:
10.09.2020 12:47 »
Thanks for the help, the two transformer will be the same but I don´t know if the differences between one unit and other would be enough to cause problems...
Best Regards.
Striker52
1.657
Antwort #3 am:
10.09.2020 23:22 »
Let it be!!!
Drucken
Seiten: [
1
Nach oben
« vorheriges
nächstes »
