What relays should i use for dual rectifier 3 channel
  • 8 Antworten
  • 7689 Aufrufe
rico
Hi! What are the parameters for the relays in dual rectifier? Nothing is shown on the schematic ???
Offline TubeLeo
  • 323
  • Kauft nie einen Flextone "sch... Teil"
Re:What relays should i use for dual rectifier 3 channel
« Antwort #1 am: 20.03.2005 14:17 »
I am not sure about the parameters of these "relays".
I use some kind of photocoupler which i made by myself. LDR - LED kombination. Did you see Guidos amp? There are some pictures of them.
But I think it should also work with other photocoupler relays.
Hmm  trial and error
« Letzte Änderung: 20.03.2005 14:18 von TubeLeo »
rico
« Antwort #2 am: 20.03.2005 16:03 »
Oh, i see.. So i can use one of those VTL5C9 optoisolators from vactec?
rico
« Antwort #3 am: 21.03.2005 11:43 »
Someone? SOS
Offline Joachim
  • 3.704
  • Live long and prosper
« Antwort #4 am: 21.03.2005 12:03 »
Hi Rico,
They should work.  Also I think, Mesa use this parts in his amps. But it is a VTL5C1 not a VTL5C9. Unfortunately this parts are really expensive :(
Joachim
Live long and prosper.
rico
« Antwort #5 am: 21.03.2005 15:13 »
Should i use it instead of relays or along with relays? Cause on 3-channel dual recto schematic only 2 optoisolators, but more than 10 relays. Someone knows what does it mean?
And i also need to ask about LM3914 chip. What is it for???? What it does?? It's required or not?
Thanks!
rico
« Antwort #6 am: 27.03.2005 11:33 »
Someone, help! Need parameters for the relays :'(
Offline TubeLeo
  • 323
« Antwort #7 am: 27.03.2005 13:23 »
I do not have the schematic for the 3-channel-dual-recto but I think that the LM Chip is for the stabilization of the DC-voltage -6,3V - you need to heat the preamp tubes. You do not really need to head all 12AX7 with DC. But most head V1 with DC to reduce interferences. So the chip is not really necessary.
Did you see other (older) schematics from the 2-channel-version of the amp. There you will see other opportunities to create the direct voltage needed for V1.
There you will also see that mesa used for all switches LDR`s. So I would use some kind of optocoupler for all switches. For some MOSFET Transistors should also work.
I hope I could help you a little bit. In these Forum are some other cuys they are much more familar with these recto amp than me - but I think they are afraid to write in english.
Bye the way - sorry for my english  ::)
Bye
Offline TubeLeo
  • 323
« Antwort #8 am: 27.03.2005 13:44 »
 ;D
« Letzte Änderung: 27.04.2005 13:24 von TubeLeo »
