TT66 Head Cabinet Room for Tubes
  • 3 Antworten
  • 3260 Aufrufe
Offline Carruw
  • 4
« am: 7.07.2012 17:07 »
I hope you won't mind me writing in English since my German isn't very good.
I've just completed the build of a TT66, and may I just say what a fantastic amp it is. Such good clean tones and absolutely no noise or humming.
I now plan to build a head cabinet and I wonder how much extra room I should have between the KT66 tube, which is the biggest, and the top wood.
I plan to use some sort of grill to help ventilation and the back will be completely open.
How much would you say is enough? A few centimeters?
Thanks for helping.
/Carruw
« Letzte Änderung: 7.07.2012 17:08 von Carruw »
  • 12.971
Re: TT66 Head Cabinet Room for Tubes
« Antwort #1 am: 7.07.2012 19:52 »
we build the headshells for the TT66 with an internal high of 205 mm.Works pretty good. You don't need an ventilation on the top of the headshell.
Regards, Dirk
Offline Carruw
  • 4
« Antwort #2 am: 7.07.2012 21:08 »
Thank you for answering.
I rarely play loudly but I wanted to be sure.
Thanks again.
Hopefully the build will come out fine. I'll post some pictures when it's done.
/Carruw
Offline Fl@shR!Der
  • 407
« Antwort #3 am: 8.07.2012 14:30 »
 :topjob:
Schöne Grüße Reinhard
