My SLO Clone Build
  • 58 Antworten
  • 34930 Aufrufe
Offline FourT6and2
  • 46
Re: My SLO Clone Build
« Antwort #30 am: 20.07.2014 03:49 »
Most of the power section is done. Once the preamp is wired up I can finalize the remaining connections on the power board. It's not as tidy as I really want. But there are a lot of wire runs in the SLO. Good thing they're all covered by the power PCB :) And I spliced in the lead from the OT to the HT Fuse.
Offline Jürgen
  • 406
« Antwort #31 am: 20.07.2014 04:06 »
 :topjob:
Offline FourT6and2
  • 46
« Antwort #32 am: 21.07.2014 09:02 »
Elevated heater mod wired up. This part was like playing that Operation board game.
Offline FourT6and2
  • 46
« Antwort #33 am: 22.07.2014 15:53 »
Damn, power tube sockets took a long time. But they're finally done. Just need to add some heat shrink to the grid stoppers. Next steps will be the loop jacks, impedance selector, and then I can move on to the preamp board wiring and I'll be done.
Offline mc_guitar
  • 1.379
« Antwort #34 am: 22.07.2014 17:41 »
Hello,
Looks incredibly tidy! thumbs up for your superb work!!
 :topjob:
Cheers Michael
Offline FourT6and2
  • 46
« Antwort #35 am: 23.07.2014 09:01 »
Output jacks, impedance selector, and FX loop return wired up. I'm not going to do the slave out. I never use it. And I can always add it later if I want to run wet/dry or something.
Offline FourT6and2
  • 46
« Antwort #36 am: 25.07.2014 09:01 »
So close!
Had to figure out a way to hold the preamp board up off the table, while at the same time keeping the lead I was soldering from falling out since they're installed from the top of the board. That's where these Helping Hands come in handy. Was pretty easy. :)
  • 5.813
« Antwort #37 am: 25.07.2014 09:47 »
Awesome.
The slave out is useful if you want to record thru Torpedo's software. Then you can skip the power amp simulation. Just hook the amp to a load, Mike.
  • 2.461
« Antwort #38 am: 25.07.2014 14:14 »
That's going to be an awesome amp, great build quality.
Is there a particular reason why you used the "purple wiring code"? (just kidding ;D)
Cheers Stephan
Offline FourT6and2
  • 46
« Antwort #39 am: 25.07.2014 16:17 »
Purple sounds better!
Offline FourT6and2
  • 46
« Antwort #40 am: 26.07.2014 05:06 »
Got the AC lines, Depth control, loop, and channel switch all wired up. Board is now locked in.
Offline FourT6and2
  • 46
« Antwort #41 am: 27.07.2014 08:44 »
Was out doing real-world stuff for the majority of the day. So did a couple of the small things left to do here and there: Power Board to Preamp Board jumpers for Bias, B+, and Ground; signal coax to V3/7 (not shown); and remote bias control.
Offline FourT6and2
  • 46
« Antwort #42 am: 28.07.2014 04:09 »
Yay, all done! :)
Just gotta do some testing to make sure all the voltages are good. Keeping my fingers crossed.
High Res Version: http://fc08.deviantart.net/fs71/f/2014/208/5/f/slo_clone_1_by_haftelm-d7sk7t6.jpg
Offline FourT6and2
  • 46
« Antwort #43 am: 28.07.2014 05:58 »
Powered up. No smoke, no sparks. Everything seems good. :) I think all the voltages check out for the most part. Some are a bit higher, some lower. Plate voltage is crazy high... 520 volts. Damn. Highest I've seen in any amp.
TARGET:
ACTUAL:
Offline Laurent
  • 2.029
  • Nichts ist unmöglich
« Antwort #44 am: 28.07.2014 06:58 »
Really nice job!! Looks amazing  :topjob:
Waiting for the final test: walls shaking test in the house  ;D
Is the voltage of the PI V5-pin 6 a typing mistake? Should probably be 257.9 instead of 357.9V, right?
Cheers,
Laurent
