Hilfe VoCo VVR einbau
  • 15 Antworten
  • 6463 Aufrufe
Offline Guile
  • 38
« am: 9.09.2014 14:01 »
Hello, Is there a guide to install the TubeTown VVR on the TT forum? I want to install it in my Reverb Deluze clone.
I really need some help. I don't want to make mistakes!
Danke
Offline The stooge
  • 647
Re: Hilfe VoCo VVR einbau
« Antwort #1 am: 9.09.2014 14:19 »
Hello,
Here You will be helped: https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control
ne schöne Jrooß, Mathias
Offline Guile
  • 38
« Antwort #2 am: 9.09.2014 14:28 »
Thanks, I read that, but I need more specific instructions if possible.
Offline Hardcorebastler
  • 874
« Antwort #3 am: 9.09.2014 14:35 »
Security
Tube amps contain life-threatening voltage! Only people with
sufficient knowledge and experience should fit the VoCo to an
amp. Anything else is grossly negligent!  ;)
Offline Guile
  • 38
« Antwort #4 am: 9.09.2014 14:38 »
Thanks grandpa, but where can I learn then?
Btw I built the Deluxe Reverb myself and I'm still alive  ;)
Offline sev
  • 853
« Antwort #5 am: 9.09.2014 14:56 »
Hi Guile,
Take a look at Merlin Blencowe or Morgan Jones, both wrote great books.
Merlins site: valvewizard.co.uk
Greets
Sev
P.s. what info do you miss?
--Edward Murphy
  • 1.243
« Antwort #6 am: 9.09.2014 15:06 »
Hello,
built and assembled is a significant difference in my book. Great tips from sev.
Best,
Offline Hans-Jörg
  • 1.378
« Antwort #7 am: 9.09.2014 16:22 »
Hi Guile,
the link in the second thread should provide you with the desired info.
You could also google the "London Power scaling from Kevin o`Connor" for more info.
And the above mentioned books for shure!
Hans-Jörg
Offline Guile
  • 38
« Antwort #8 am: 9.09.2014 16:39 »
Thanks, but I got no time to read books, gotta play my guitar!
Does the 'out' coming from the pcb goes to pin 4 of one of the two 6L6 power tubes?
I just need to know where the three wires go. Let me worry about safety and being knowledgeable.
Thanks
Offline The stooge
  • 647
« Antwort #9 am: 9.09.2014 16:58 »
Hello,
"out" is connected to both screen grids of the power tubes (instead of the one in the schematic https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control). Complicated, isn't id?
Mast- und Schotbruch un ne schöne Jrooß, Mathias
Offline Guile
  • 38
« Antwort #10 am: 9.09.2014 17:02 »
Thanks for helping out
Offline Guile
  • 38
« Antwort #11 am: 9.09.2014 17:27 »
Can someone explain where the B+ goes? Do I simply need to tap it of off B+?
Btw, the layout on this page is so small, I can't read it clearly: https://www.tube-town.net/cms/?DIY/Amp-Tools/VoCo_Variable_Voltage_Control
« Letzte Änderung: 9.09.2014 17:31 von Guile »
Offline sev
  • 853
« Antwort #12 am: 9.09.2014 18:33 »
The output of the power tubes can be controlled by the voltage on the screen (G2). For this purpose, the TT-VoCo is insterted in the screen power supply.
Further questions?
The given schematic is an example how the VoCo can be used, in thr particular case in the TT66.
The page provides sufficient info about the way the VoCo works.
If, after reading this documentation, it is not clear how the VoCo is installed and used, it indicates a level of knowledge insufficient to safely and correctly install the VoCo in an amplifier. In this case, we strongly recommend letting an experienced technician do it.
Greets
Sev
--Edward Murphy
« Antwort #13 am: 9.09.2014 18:34 »
Sorry, but I wonder how you managed to build your Deluxe Reverb, if you ask such questions  ???
You'd better go to a professional technician. Just my 2 cents.
Axel
Offline Guile
  • 38
« Antwort #14 am: 9.09.2014 19:05 »
Proof that tube-amplifiers are not rocket-science. It's the crudest form of electronics possible; just follow the layout and pull the switch.
Every second spent fiddling in amplifiers is time lost not making music!
Just my 2 cents
Over and out.
