Single-channel DR
  • 11 Antworten
  • 8168 Aufrufe
sjhusting
Single-channel DR
« am: 11.12.2014 17:33 »
Hi Folks -
I haven't been around much the last couple years other than to make
occasional sarcastic comments, but I thought I would share my latest
build with you - and my first build in two years. I don't really need
any new amps; I don't have space for any more amps; but I was missing
a DR and it is a useful configuration for what I am doing right now.
This one is a vibrato-channel only Deluxe Reverb. It's built on a
Hoffman board (turrets, different layout) with bias-vary tremolo. The
layout is reversed from normal because the TT 004 I had has the IEC
cutout on the "wrong" side. I just flipped the board, but this means
some leads cross when they otherwise wouldn't. Lead dress is ok, I
don't think I'll ever do HiWatt quality dress. Iron is Hammond. It's
ready to be tuned - this is mostly trying the new Sozo blue molded,
possibly swapping the Dale anode resistors for CC, tweaking the
tremolo depth and speed, and taming the reverb (there is just too
much).  The amp is very quiet - actually it is the quietest amp I've
ever built, with no noticeable hum at all, and not much hiss.
The cab is solid pine, half-blind dovetails, with smooth blond
tolex. Still having trouble with Tolex at a few points. Baffle
is 15mm voidless birch ply with oxblood grillcloth. I
added tiltbacks just because I like how they look. The speaker is a
JBL D120F I bought from someone on the forum. It was reconed at some
point. I don't know if it is an original JBL cone (unlikely) but it
sounds quite good and if after a month or two I decide I don't like it
I'll replace it with a Blackbird. Faceplates from Dirk, of course.
Right now I have various new tubes in it - "Tung Sol" and "Mullard"
12AX7, RFT 12AT7 (ok, not new), "Tung Sol" 6V6, and JJ GZ34, but I
will be tube-rolling GE & Phillips 5751, RCA, GE, Philips/Sylvania
12AX7, Sylvania 12AT7,  various NOS GZ34 and 5R4, and whichever NOS
6V6s I decide on - either JAN GE, 70s Sylvania, Bendix, or
Brimar. Really it sounds fine now; I can easily live with it the way
it is. It sounds like a Deluxe Reverb.
« Letzte Änderung: 11.12.2014 17:36 von Puddnhaid Husting »
haebbe58
Re: Single-channel DR
« Antwort #1 am: 12.12.2014 07:27 »
Hi Steven,
 :topjob:
einfach nur klasse!
  • 5.813
« Antwort #2 am: 12.12.2014 10:31 »
Awesome.
May I ask you a favour? Could you please be so kind and post
a) which chassis from the shop (for the amp, not the combo) you've chosen (stupid me, TT004 or so)
b) could you please attach the templates for the front/back. I have a spare xformer and 2 weeks off soon . . .
pretty please . . .  ;D
Thanks
« Antwort #3 am: 12.12.2014 14:37 »
Hi Steven,
well done. Looks like a classy classic.  :topjob:
Offline LöD
  • 2.348
« Antwort #4 am: 12.12.2014 14:50 »
smooth white with oxblood, mjamm. The perfect match. And I also like JBL AlNiCos with blackfaces...
LöD
sjhusting
« Antwort #5 am: 12.12.2014 18:07 »
Olaf - will do. PDF ok?
sjhusting
« Antwort #6 am: 12.12.2014 20:46 »
Olaf - if you need a different format (corel draw, visio) let me know.
steve
  • 5.813
« Antwort #7 am: 13.12.2014 06:54 »
Perfect, thanks a ton Steven
Offline RoehrenJeans
  • 625
« Antwort #8 am: 13.12.2014 09:04 »
Hi Steve,
Just Perfect !!
 :topjob:
... BONEHEADS WILL CERTAINLY DIE ...
You made my day !
Stoffel
Offline sev
  • 853
« Antwort #9 am: 13.12.2014 10:02 »
Hi Steve,
beautiful Amp, is it Fender smooth blonde Tolex or TT Blond?
 :topjob:
Sev
--Edward Murphy
sjhusting
« Antwort #10 am: 13.12.2014 17:28 »
Hi Steve,
 :topjob:
Sev
Hi Sev
Fender smooth blonde. I bought a lot of it before Dirk had the TT
Steve
sjhusting
« Antwort #11 am: 16.12.2014 17:32 »
Well, I'm done tuning. I left the Xicons in, and didn't even bother trying the Sozos. The Xicons sound fine, like they always do. I did slow down the trem and tweak the negative feedback. I also discovered that when you make a mistake and use a 47k instead of a 47R for the bottom half of the NFB voltage divider your signal gets very small  :facepalm:
All NOS tubes (except the oscillator) and the 6v6s - Sylvanias are on the way. I really like this amp. I have a line on some RCA blackplates, too, but I've always liked Sylvania 6V6s.
steven
