Need help SLO 50 clone
  • 66 Antworten
  • 34205 Aufrufe
Re: Need help SLO 50 clone
« Antwort #15 am: 11.10.2016 17:18 »
I made a couple of quick samples of the the two Slo's. The first riff is the SlO100, the second is the SLO50.
All pots are dialed in at 12:00.
https://soundcloud.com/guilese/comparison-slo-clones
To my ears the SLO50 sounds like a Behringer amp...
When it sounds like a Behringer, i think you build a Behringer....   :devil:
Your Link is dead:
We can’t find that track.
Did you try to access a private track while not being signed in?
Maybe the track has been removed.
The reason for the bad sound is not the power supply.
Please do what I have recommended:
Rebuild (= rewire) the AMP step by step.
Shorten the Cables to the Tube sockets
use different colors for cables
don´t tie Signal cables together
Regards
Offline Guile
  • 38
« Antwort #16 am: 11.10.2016 18:22 »
Stone
« Antwort #17 am: 11.10.2016 18:29 »
I agree to Jürgen.
Why re-wiring and cleaning it up? It is hard to follow the wires within the pictures; also it might be hard to follow them with the amp opened up on the workbench - this is one of the major faults people do and have got in their amps.
Using different and correct color codes ensures that people are reading the same out of schemes and pictures of wiring - it is hard to tell about  the "thin black wire to the left" and the "a bit more meaty wire across the thin left black wire running to the right side" ;) You get me?
Do answer your question concerning FX loop.
As far as I can see there is a 1k resistor soldered from signal tip to ground, which has to be 1 Meg (I cannot read the color code of it, so I might be wrong).
At second I cannot see how you made a ground connection for FX send jack and FX return jack. Are both jacks of switching type? I assume … check the wiring and if there is no ground connection you will not have any reference for the signal to be fed into another amp / fx return.
Do not use the shield as ground connection, as you will create a hum loop by using it in most cases (and I think so in this one).
The SLO is not the most complex and complicated amp, but it is also not a beginners DIY project … again, re-wiring will help to sort out things.
And if it comes to several amperes it seems current will always flow straight forward - but that 's another story ;)
Regards, Stone
Offline Guile
  • 38
« Antwort #18 am: 11.10.2016 18:39 »
I ran the SLO50 (+ guitar) send into return of the SLO100. I have to open up the master and preamp of the SLO100 to have audible sound. Volume is very weak and thin with a hum.
Stone
« Antwort #19 am: 11.10.2016 18:51 »
Yes - which is quite normal to my opinion if there is no correct ground connection of the fx send and fx return jack of the SLO50 (this could cause the weak sound internally of the SLO50).
Regards, Stone
Offline Guile
  • 38
« Antwort #20 am: 11.10.2016 18:54 »
Thanks for both replies.
Please tell me how to correct this. Would you have a comprehensible picture of the send/return?
Only the upper jack has a switch btw
could this be the cause of the bad sound?
nb I already reflowed all the solder points. I'm not sure that changing the wire of the entire amp and making the same connections will make the amp work though..
« Letzte Änderung: 11.10.2016 18:56 von Guile »
« Antwort #21 am: 11.10.2016 19:23 »
Currently your AMP looks like if someone had done spaghetti in the chassis.... :o
The cables at the Tube sockets and many other are much too long - shorten the cables.
If you do not know how, look at the attached Picture....
« Letzte Änderung: 11.10.2016 19:27 von Athlord »
Offline Guile
  • 38
« Antwort #22 am: 11.10.2016 23:30 »
I understand you don't like the way the amp looks, message received. But is there any proof that shortening the wires will change the way it sounds?
Thanks for the pic of Mike's work, true piece of art.
« Letzte Änderung: 11.10.2016 23:43 von Guile »
« Antwort #23 am: 12.10.2016 06:56 »
Yes, the Signal ....  :o
« Letzte Änderung: 12.10.2016 07:01 von Athlord »
« Antwort #24 am: 12.10.2016 09:00 »
there are multiple reasons why you need to tidy up the amp. First, it's nearly impossible to debug an amp with a chaotic wiring, even if you have the amp in front of you and do know what to look for, much more so from pictures alone.
Moreover, loose wiring can cause all sorts of problems especially in a high gain amp such as the SLO. There will very likely be a lot of crosstalk in your amp, which can lead to multiple problems, including frequencies being canceled out and oscillation. Both problems are very likely to occur in your build.
There's a reason amps like the SLO are built the way they are, and those reasons are not purely esthetically.
Cheers Nils
Stone
« Antwort #25 am: 12.10.2016 09:43 »
For a short check it will be satisfying to draw a wire from fx loop jacks ground connection to speaker jacks ground connection - a detailed picture of the fx jacks can be found in Joachims "SLO 100 Schritt für Schritt" Thread at this point: http://www.tube-town.de/ttforum/index.php/topic,3292.msg31779.html#msg31779
There is also a pretty well working ground scheme http://www.tube-town.de/ttforum/index.php/topic,3292.msg36124.html#msg36124
To have the fx ground connected to speaker jacks ground is just for testing and may cause hum. But from my point of view it will not work without any ground connection.
If you are using a switched jack for fx send it will do (more or less if you are not using fx return with another preamp or so), but having both ones of switched type is the better choice (and ... which one is the upper one? Chassis top over on the desk or ... ;-) ).
Nils nailed it - shortening the wires leads to better overview and therefore analysis of problems is much easier. Some people build there amps in a very "esthetic" way if it comes to wiring, but the nice view is a plus beneath the elimination of all kind of unwanted noise.
Regards, Stone
Offline Guile
  • 38
« Antwort #26 am: 12.10.2016 14:03 »
Hi guys, thanks for the information and explanation, makes a lot of sense. I will get to it.
But the SLO100 clone which I bought a while back looks like this:
https://www.flickr.com/photos/115176149@N03/?
(Jurgen try not to vomit  ;) )
It sounds great though.. And as far as I can determine it is the same as the SLO50. Same part-values and voltages.
I tried the fx loop instructions, but no result..
« Letzte Änderung: 12.10.2016 14:05 von Guile »
Offline _peter
  • 1.925
« Antwort #27 am: 12.10.2016 14:14 »
Well, it does have shorter cables.  ;D
At least where it counts.
Gruß, Peter
Offline Guile
  • 38
« Antwort #28 am: 12.10.2016 14:46 »
Hope this link works (grrrr): https://soundcloud.com/guilese/slos
All pots at noon
« Letzte Änderung: 12.10.2016 14:53 von Guile »
Offline Guile
  • 38
« Antwort #29 am: 12.10.2016 14:55 »
I agree to Jürgen.
Regards, Stone
Stone, the fx/send is in ordnung. Can you please tell me which setup to make?
Both amps on Normal channel
Send SLO50 to return SLO100
Guitar in SLO50
And then?
