Fender 6G15 - das Geheimnis des "Drip"
  • 15 Antworten
  • 8789 Aufrufe
Offline MotorBongo
  • 6
Re: Fender 6G15 - das Geheimnis des "Drip"
« Antwort #15 am: 1.11.2018 19:50 »
in my other amps I use a similar circuit, but with the two systems of the 12at7 to drive the pan. This gives a more powerful reverb, closer to the 6G15. More or less the original 6G15 with the driver circuit of the AB763.
Andreas
Hi Andreas,
Thanks for the added info. While your YT-clip of today showed that it can get pretty 'wet', I could understand there's 'close' and 'closer' to the 6G15 ;-)
I had a look to see whether (for an easy straightforward standalone version)
I could supply your two-tube version from one Tube-Town 12VDC to 220VDC stepup-board,
but that didn't look too promising (15mA max, and the 220VDC probably just leaves one wondering if it's enough), so while building anyway, I guess it's better to go for more tube-sections. Still a nice approach that you shared, thanks!
Have a good evening!
