TT 150ma 640vct PT with 6l6?
  • 6 Antworten
  • 2210 Aufrufe
Offline Nicklas
  • 3
« am: 6.01.2020 15:16 »
Has anyone tried using TT 5e3 power transformer, 150ma 640vct, with 6l6gc tubes in fixed bias?
Will it survive?
I will use a gz34. The TT 5e3 pt is cheaper than hammond 290dex. I'd like to build a 5f6a which can use 6v6 or 6l6. The Jtm45 pt is usually only rated at 150ma with 690vct so maybe it will be a low power bassman??
Offline roseblood11
  • 1.227
« Letzte Änderung: 6.01.2020 18:30 von roseblood11 »
  • 3.936
Offline Nicklas
  • 3
Re: TT 150ma 640vct PT with 6l6?
« Antwort #3 am: 7.01.2020 15:30 »
https://www.tube-town.net/ttstore/tt-netztransformator-fender-style-5e3-high-power.html
... but it doesn't have a bias tap
Yes but I will just take the bias from 320vac instead.
The TT 5e3 6l6 PT is rated 640vct 300ma which seem to be more than I need. Good price though. I will ask TT directly about this.
« Antwort #4 am: 7.01.2020 20:23 »
Will it survive?
NO !!!
Regards, Dirk
Offline Nicklas
  • 3
« Antwort #5 am: 9.01.2020 20:58 »
NO !!!
Regards, Dirk
Ok
Will the 5e3 300ma 6l6 pt work?
If I make it fit on the chassis and take bias from 320vac tap.
Regards
Nicklas
« Antwort #6 am: 9.01.2020 22:10 »
The 5E3 HP Powertransformer will do the job.
Best regards, Dirk
