Impressum |
Datenschutz |
Shop |
DIY |
TT @ Twitter |
TT-Cabs
Einloggen
Registrieren
Suche
Übersicht
Hilfe
Suche
Einloggen
Registrieren
Tube-Town Forum
Technik
Tech-Talk Fender
TT-5F1 v2020 Center Tap
« vorheriges
nächstes »
Drucken
Seiten: [
1
Nach unten
1 Antworten
1494 Aufrufe
Bobble4130
Newbie
1
am:
28.03.2020 18:05 »
Hello,
I received the TT-5F1 v2020 kit with the 5E3-VPO transformer wich has a CT 6.3V
Is it better to connect it direct to the ground and delete the artificial CT (R103 and R104) to decrease the hum?
Is my layout correct?
Thanks
Dirk
Dirk M.
Administrator
YaBB God
12.963
2T or not 2T
WWW
Re: TT-5F1 v2020 Center Tap
Antwort #1 am:
28.03.2020 22:31 »
please build it with the R103 and R104. This version is tested many times and known to work. After you are sure that the amp works as it should then you can start to change things if you want.
Best regards, Dirk
Drucken
Seiten: [
1
Nach oben
« vorheriges
nächstes »
