Dual Relay
  • 8 Antworten
  • 1858 Aufrufe
Offline warioblast
  • 7
Dual Relay
« am: 1.04.2020 19:37 »
Hey guys,
How can I mod TT dual relay board https://www.tube-town.net/ttstore/kit-double-relais-switcher-6-v.html to work with a mono footswitch pedal.
Offline warioblast
  • 7
Re: Dual Relay
« Antwort #1 am: 1.04.2020 20:48 »
I noticed a pin of the cliff jack is connected to ground. I'm thinking this shoud do it.
Re: Dual Relay
« Antwort #2 am: 2.04.2020 08:56 »
It works already with a mono plug.
Best regards, Dirk
Offline warioblast
  • 7
Re: Dual Relay
« Antwort #3 am: 2.04.2020 15:19 »
Hello Dirk & thank you for the support.
I would like to switch the 4 switches of the 2 relays at once with my mono Marshall footswitch.
Re: Dual Relay
« Antwort #4 am: 2.04.2020 19:20 »
yes, this works. You did not test ?
Dirk
Offline warioblast
  • 7
Re: Dual Relay
« Antwort #5 am: 3.04.2020 17:29 »
With my Marshall footswitch; mono; it only switches the Relay 2. The Relay 1 is on all the time.
Offline warioblast
  • 7
Re: Dual Relay
« Antwort #6 am: 3.04.2020 18:17 »
I'm thinking I should cut the trace that goes from the ring (?) to the - pin of the relay 1.
And from the - pin of the relay 1, going to one of the tip pin. It should be 50-50, right !?
Offline warioblast
  • 7
Re: Dual Relay
« Antwort #7 am: 3.04.2020 18:20 »
Offline warioblast
  • 7
Re: Dual Relay
« Antwort #8 am: 3.04.2020 18:46 »
 ;D
