doubling current with two parallel transformers.
  • 3 Antworten
  • 1329 Aufrufe
Offline Leadman
  • 58
Hello
Is wiring two TT 50VA power transformers correct for build a 4xel84 style amp? I need the exact voltage that the TT 50Va put but I am thinking about build a pro junior style amp with 4xel84 for gigging in bigger pubs.
Best Regards.
Offline dimashek
  • 517
Re: doubling current with two parallel transformers.
« Antwort #1 am: 10.09.2020 11:33 »
This will work only, if the transformers are exactly same! Same winding number in Primary/Secondary.
I would not try this
Offline Leadman
  • 58
« Antwort #2 am: 10.09.2020 12:47 »
Thanks for the help, the two transformer will be the same but I don´t know if the differences between one unit and other would be enough to cause problems...
Best Regards.
« Antwort #3 am: 10.09.2020 23:22 »
Let it be!!!
