Power Transformer for AX84 Hi-Octane with LND150 FX-Loop
  • 15 Antworten
  • 3039 Aufrufe
Offline kvdmeulen900
  • 17
Re: Power Transformer for AX84 Hi-Octane with LND150 FX-Loop
« Antwort #15 am: 4.02.2021 11:02 »
No issue with your heater current as long as you don't implement DC heaters for the preamp. The "old" RKT 30VA was designed with that in mind. I think it is also used in the small Jim amp.
Since the “old” 30VA was used in the 5W Jim amp, I suppose it’s safe to use for my purposes as the current draw is roughly the same.
I’ll start building the amp and will post the results when it’s done  ;D
