EL34 Mullard bias problem
  • 4 Antworten
  • 1207 Aufrufe
Offline danieleb
  • 36
« am: 23.12.2023 13:16 »
Hi, I have a quartet that I use in my YAH100, I use it for the first time with my band (so not at home at 0,000001 MV  ;D). I checked my bias before (60 and 60 each couple), after playing I find the bias of one couple at 90. I reset the dias to 60, but today I find it real low (something like 40), but after playing at high volume, after, I find it high.
I tryied inverting the tubes and the problem follows the problematic duet. I tryied with my old tubes (JJ) and no problem at all.
So I think could be one of the 2 tubes of the problematic duet, I can't hear sonic problem.
Any Idea?
Thank you
Offline Helmholtz
  • 358
Re: EL34 Mullard bias problem
« Antwort #1 am: 23.12.2023 15:40 »
If possible, please find and post the schematic.
Yes, it seems one of the Mullards has a problem.
Offline danieleb
  • 36
Offline Helmholtz
  • 358
« Antwort #3 am: 23.12.2023 18:32 »
Ok, so the amp uses a 1R current sense resistor per side (i.e. for 2 parallel tubes).
If you insert only one EL34 per side (e.g. in V5 and V6 positions) you can monitor the idle current of each tube separately. Should give you 30mV to 35mV across the 1R resistors.
This way you should be able to identify the tube with instable idle current.
Offline danieleb
  • 36
« Antwort #4 am: 24.12.2023 12:40 »
Thank you, I hope to find a matched mullard to save the quartet
