Schaltplan Kitty Hawk Standard
  • 53 Antworten
  • 33152 Aufrufe
Offline reverbus
  • 18
Re: Schaltplan Kitty Hawk Standard
« Antwort #45 am: 9.03.2014 21:18 »
Thank you Manfred!
I'll add this info to my schematic.
I plan to make a clone of Standard, but need a perfect output trafo.
So, it will take some time. Probably I will wind it by myself.
Goodluck with your Kitty Hawks!
I did repair Junior Pro too.
Regards,
Iztok
Manfred
« Antwort #46 am: 10.03.2014 10:29 »
Hi Iztok,
a further hint regarding the power transformer.
In your PSU part drawing both hot ends of the transformer are denoted by a value of 750 Volts.
I guess, the total voltage between the hot ends is 750V
and each voltage on the hot end in respect to the coil tap is 375 Volts.
Regards,
Manfred
Offline reverbus
  • 18
« Antwort #47 am: 10.03.2014 14:26 »
Hi Iztok,
Regards,
Manfred
Hi Manfred,
yes, 750VAC between taps and half (375VAC) from each tap to CT (center tap).
Note: my mains voltage at that time was 216VAC!
At higher mains voltage (230-240VAC) you should see higher AC on the other side of transformer.
Because heater voltage is already over 6.3VAC (6.42VAC on my schematic), further increase would not be welcome.
Regards,
Iztok
« Letzte Änderung: 10.03.2014 14:30 von reverbus »
Manfred
« Antwort #48 am: 10.03.2014 20:44 »
Hi Iztok,
thanks for your hint.
At the development periode of the early Kittys the main voltage has been 220 Volts in Germany.
I suppose the power transformer has been not well calculated.
Regards Manfred
Offline reverbus
  • 18
« Antwort #49 am: 11.03.2014 15:32 »
Hi Iztok,
Regards Manfred
Hi Manfred,
I think Roy didn't take care how we will manage mains voltage many years after :)
I had a Counterpoint on my bench... I could read heaters voltage of no less than 7.1VAC (at mains voltage today=235VAC).
Regards,
Iztok
  • 3.932
« Antwort #50 am: 11.03.2014 21:43 »
Hi Manfred,
Regards,
Iztok
Hi Iztok,
i think the roys did not take care of a lot of things. IMHO they did not understand a lot of things....
I met one of them personally on the Frankfurt Musikmesse and asked him about the "correct" way to hook up speakers to my counterpoint supreme....
Question: "I have three outputs 2 of them labelled 4 ohm, 4 ohm and one labelled 8 ohm. What's about the two 4 ohm Speaker outs? Can I use two 8 ohm speakers there"
Answer: "NO - The two 4 ohm speaker outs are intended for the use with two 4 Ohm Speaker cabinets"....
Sorry - but this answer was simply - WRONG.... It's copied from MESAs - use for a combined 4 ohm load... Either one 4 ohm or two 8 ohms in parallel...
Otherwise something to mention: my Kitty had a scorchmark at one tube socket from minute one onwards, a clear indication, that it had been used with a too high speaker impedance, or no load at all. From the factory
To be honest: My respect for the original KittyHawks is very low. My counterpoint IS a nice amp; but IMHO this was simply by accident and not because of the technical knowledge of its makers....
The pics on in your gallery - thank you for these - speak the same language.... I simply don't understand, why the standards are compared to dumbles.
regards
Offline reverbus
  • 18
« Antwort #51 am: 12.03.2014 10:00 »
Hi Jochen,
I did repair/restore 5 Kitty Hawks so far.
2 of them sounded great without tweaking, the rest were somehow modded to get best out of them.
I can't judge Roy, I don't know the whole story, but - every amp is a bit different (same model), would be nice if schematics are followed.
Looks like all of them were a bit "custom" made, especially preamps.
Amps from my bench are all pretty old, 80'-85', so are early models.
Indeed, labelling outputs that way is strange:-), very confusing for the user.
In general, I may agree with you regarding respect, but you can find great sounding KH if you can choose.
Those should be early models, from my experience.
Regards,
Iztok
Offline Irie
  • 1
« Antwort #52 am: 20.11.2014 16:16 »
ist zwar ein alter Thread, aber ich bräuchte ebenso den Schaltplan zu dem Standard.
Könnte ihn mir jemand schicken?
Vielen Dank euch und besten Gruß
Irie
Offline Mr. Lime
  • 402
« Antwort #53 am: 28.11.2014 13:10 »
Sind doch eh auf Seite 2 und 3 angehängt..
